Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Error message Hello, I have an Hp dv2221 notebook. It is just over a year old and just out of warranty. When i turn it on all that happens is an error code ERR01ERR03 appears then if you hit f11 to try and get the system restore on it does nothing i can however get the esc or f10 button to work with Phenix Bios but not sure what to do in this situation teste hard drive in the f10 net bios page it is saying it is ok. Do you have any idea waht this issue is? Any help would greatly be apprecaieted
  • 186 Answers
Hey, your Notebook is among the one which is having some known issues if it is purchased in US. Check with the Product Number of the Notebook which should be printed on a white sticker at the bottom of the Notebook indicated with P/N.
Try finding it from the ones listed in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01300427&dlc=en
Also, you can find more information about this known issue from the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01087277&dlc=en
Contact HP Chat Support since the Notebook is out of warranty and inform them that the Notebook is out of warranty.
You should be provided with free repair options. If not, provide the link I had provided above.
All the best.
Posted on Aug 14, 2008
C4780 printer cartridge problem cannot fix problem is this same as ink cartridge problem what do i do tried cleaning ink cartridges but still says samething on display it happend in middle of printing...
Ok. As per your statement , the power cable is working properly. So , the problem is with your printer only. If you are using the original cartridges and still having the priblem , it is only the defualt printer. If you are having the extended warnty for (3) years , you are adviced to contact ' HP Authorised Service Partner'. they will replace your old printer with new one. Generally the HP company is giving 1 OR 2 years warranty for replacement.If have paid extra amount for extended warranty , your printer may have warranty up to (3) years. So, within the period of (3), the HP Authorised Service Center will replace your printer. They will give reciept for your old printer, and replace your prionter within a (15) days to (25) days with new one. If the printer is not having warranty or extended warranty , the printer is assumed to be as damaged. So, you have to purchage the new one. Be, cuacious the HP printers are not repairable. Please don't try to approach the local repairer.They will eat your money and also don't try to purchase very very very costly HP in cartridges. I think your problem may be solved.
Oct 03, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
I turn on my laptop it goes to the default red and blake COMPAQ screen but there's two beep then in the top left hand corner it says 101-I/O ROM Error Joshua Jograntben@yahoo.com
Hello, Joshua.
More than likely, that error is referring to a hardware error, such as a network card.
If your notebook is still under warranty, contact HP.
If not under warranty, contact a local repair shop for an estimate.
Hope this helps.
Aug 17, 2010 | Compaq Armada M700 Notebook
There is question of soanner error 5 turn off then on ?please provide me help
Hello shaiata_jabe !
I worked with those printer for 2 years...
This scanner error 5 you are getting is hardware failure on the scanner assembly
I would recommend you to try updating the firmware to the latest version, but most of the time its not going to work.
Now heres the best solution:
If the printer its under warranty (1 year after purchase date) just call hp tech support and you can get a replacement for $69 US dolars
its better than buying the scanner assembly
If the printer its out of the 1 year warranty, theres a service note for this specific issue that will extend your warranty 1 more year, that means 2 years warranty if the problem is a scanner error 5
Hp tech support phone number is 1 800 334 51 44
If you have any other question just contact me at :
eliteprintersolutions@hp.com
Jul 12, 2010 | HP LaserJet M1522nf Multifunction Printer...
Hp m1522nf: Keep getting scanner error5. Don't use the scanner but not I can't copy with this error.
Hello !
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
Hello, i have a hp notebook which code 31 error on
http://support.microsoft.com/kb/932520
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
Feb 23, 2010 | HP Pavilion dv6000z Notebook
My HP G60-235dx will no longer power up. The
Remove the Battery and connect the AC Adapter it charges fine than Battery is Faulty replace the Battery if the Notebook is is less than 1 year old than get the battery replaced by HP for free under standard warranty if still the problem than try another Known good AC Adapter if the problem persists than send the Notebook to HP for the bench repair to repair the Notebook from HP under warranty
Oct 11, 2009 | HP G60-235DX Notebook
My HP laptop's screen (the bottom end) continuously blinks
If you have already hooked up an external monitor absolutely its the ribbon cable connecting the LCD to Laptop If its less then a year old get the warranty for replacement
Aug 10, 2009 | HP Pavilion dv6000z Notebook
HP Laptop Pavilion 2000 is on but screen is black
If you are using a AMD based Notebook, this may be one of the simptoms identified by HP earlier.
So, if your notebook is having AMD Processor, I recommend you to get the Product Number of the Notebook and check if it is listed in the weblink below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01300427
If yes and if your Notebook is less than 2 years old, you can contact HP Support and find the options to get a free repair.
Unfortunately, if your Notebook is equipped with Intel Processor, all you need to do is check the warranty and contact nearest Authorized Service center if the Notebook is out of warranty or contact HP for options.
Jan 20, 2009 | HP Pavilion dv6000z Notebook
Error message 83C00009 on HP L7680
I had the same error and I just did the following and it reset the printer back to defaults and things are working once again.
1) Turn printer off (pull power cord)
2) Press Cancel button on top of printer
3) Turn power back on (plug in power connector)
4) Keep pressing Cancel button untill it looks like it reset
Jul 30, 2008 | Office Equipment & Supplies
Hi :) plese help
remove all external devices and try again does it beep at all?
Jan 03, 2008 | HP OmniBook XE3 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
