Question about Ricoh Aficio MP 161 Black and White Copier
Setting the duplex printing for RICOH Aficio MP 3351
  • mike Jul 23, 2012
    By default, the copier setting is set to Duplex OFF. When a user adds the copier the duplex option is ON. How do I change this so that it's off by default?
  • 263 Answers
You just need to go to printing preferences and set the tab duplex. (Opens a tab and you chose which one you want.)
If you want to put duplex by default, go to:
Start - printers - click on the right on your mouse - properties - Printer preferences - and Change the duplex. In the end just click on "apply".
Posted on Feb 24, 2011
    New Friend:
I have my printer connected to my computer but i cant print once i print it is printing blank pages what are the missing drivers that i have to install so that it can print?
Posted on Feb 01, 2013
SOURCE:
Ricoh mp 2550b sc 995 solution
SC995 Serial Number Setting Incorrect The 11-digit serial number is printed on the data plate. This information is compared with the installed components to detect mismatches. Did you remove any of the machine parts or components? Reinstall anything you removed and see if the error is resolved. If it's a problem with the NVRam, you'll need to contact an expert.
Dec 02, 2014 | Ricoh RICMP2550B Aficio Mp2550B - Digital...
What is sc 532 on aficio mp c2500 and what if the machine shows your that your fuser settings error
"Fusing duplex motor locked" check the fusing duplex gear box or clean if not so you can change duplex motor.
Sep 01, 2014 | Ricoh Aficio Mp C2500 Color Laser -...
Ricoh MP 3351 shows messege SC798 , problems with finisher
Three possible cause:
- Poor connection between the finisher and mainframe.
- Finisher harness damaged or defective.
- Finisher unit defective.
For number 1 you can check the connection to make sure the connection is proper.
For number two and three, I am afraid you have to buy a new replacement unit.
Nov 09, 2013 | Ricoh Aficio MP3351
Ricoh aficio mo 3351 reads messege functional problem detected . SC819
unplug the hard drive and switch on machine, if the problem goes away, then plug the hard drive back in and format it with service code 5-832-001, normally works
Nov 03, 2013 | Ricoh Aficio MP 2000 Black and White...
How we print a document on both sides (back and front) of the paper in RICOH Aficio MP 2000L copier
Hello!
If your machine have that option you just need to go to the printer properties and select the duplex.
If you have any doubt reply to me.
See you!
Jul 07, 2011 | Ricoh Aficio MP 1600 Black and White...
I am not able to print in duplex in my ricoh 1600 Le printer pls suggest
right click on printer
properties
dublex open to left
ok
that is it
May 04, 2011 | Ricoh Aficio MP 1600L Black and White...
MY Ricoh Aficio 2550 Printer I use it via IP in windows 7 and can't print Duplex Unit it said. Duplex :(Something conflict I can't Remember) Duplex: Unit not install
In Windows 7, you can right click on the printer under Devices and Printers, then select "Printer properties" (not "Properties"), then under "Device Settings" you can set the "Duplex Unit" to "Installed". Afterwards, you can go back to "Printing Preferences"->"Finishing"->"Print on Both Sides"->Print on Long/Short Edge.
Dec 28, 2010 | Ricoh Aficio CL7200 Laser Printer
How do we get this machine (ricoh aficio MP 2000) to duplex print?
There are certain models that can duplex and certain models that can't. Generally if a Ricoh copier can duplex it has a D after the name (like 2018D). If there is no option for duplexing on the screen or the ops panel, that model doesn't support duplexing.
Apr 30, 2010 | Ricoh Aficio MP 2000 Black and White...
How do you print via computer double side print automatically with duplex on a Ricoh 1232C copier printer.? (also know asc Aficio DSC, Gestetner R032C, Infotec)
First you need to enable the duplex option in the accessories tab.
Go to printers, and sellect properties(right click) and accessories.
Feb 25, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio MP 161 is printing slanted duplex copies
Hello sir; There have two way to resolve this problem, 1st, loose the cover hinge push cover all the way to front then tighten it. then go to 2nd step open the top cover, at the left side of the white padding there have to lockes (up & down) open it out look inside there have a reverse roller, clean it with alcohal, hat should take care the problem.
Jan 27, 2010 | Ricoh Office Equipment & Supplies
Ricoh Aficio MP 161 Black and White Copier Logo
3,108 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
