Question about Toshiba Satellite P205-S6287 Notebook PC
Router If I use a wireless router to get internet on my laptop will I still be able to get internet on the go? In other words, I'm thinking of getting a router so I can use the internet at home on my laptop. If I do this, will I be able to go Starbucks and get online there, or will I only be able to use the computer at home near the router?
  • Toshiba Master
  • 2,794 Answers
Yes. You can use a wireless connection anywhere.
Posted on Jul 28, 2008
When I connect and load the Belkin software my Internet connection will not work. It is almost as if the software thinks my computer is wireless and it is not. I only bought the router to run the Xbox...
hello, are you connecting this via ethernet cable to your pc?
if you sre you should not need a disk, just simply plug in the enternet cable to your pc and the wireless router, and configure it within windows.
if not you may need to set up the router first with what ever usernames or password your ISP has provided you with
Jan 24, 2011 | Belkin Play N600 Wireless Dual Band Router...
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Wireless router will not work without my ethernet cable connected
you need to go into the router settings and turn the wireless on and then it will work
Jan 12, 2011 | Toshiba Computers & Internet
Just bought a new acer aspire one netbook, trying to connect to the internet wirelessly, got a router from our internet provider but still can't get online..how do i get the router to find the computer?
There is (I think) a switch on the side of this laptop that switches on the wireless function, if not, try the FN and one of the F keys. You should then see the wireless light come on. Depending on the router security settings, you will need to enable wireless connectivity in the router and input the password you have set whn the laptop finds the connection
Dec 25, 2010 | Computers & Internet
How to connect xbox 360 to the internet with laptop
I'm not sure if you can connect an Xbox 360 to the internet with a lap top. What I would do, is get a router (guessing that you already have one). But if you don't, it's basically a splitter for Ethernet cords. You plug the router into the Modem (the box that makes the internet), buy an Ethernet cord, plug it from the router to your Xbox and you should have internet. Or, you can get a wireless router, and get a network adapter for your Xbox to get internet wireless. But I don't think you can just get internet from your laptop.
Jul 10, 2010 | Microsoft Xbox 360 Console
Laptop driver needed
You dont need a driver for the wireless router. If your laptop can recieve wireless signal(from a wireless router) all you need is an active internet connection, configure the laptop and router to distribute the internet, you're good to go.
If your laptop cant recieve a wireless signal from a wireless router then you might need a USB Wifi Dongle.
Apr 06, 2009 | Linksys Wireless-G VPN router with...
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Belkin wireless G plus router
you will need to configure the router to connect it to the internet..please run the insatllation disc that came with it and follow all the steps..once that is done you will be able to connect to the internet via the wireless router..
please get back in case you need any clarifications..regards
Oct 31, 2008 | Belkin (F5D8231-4) Wireless Router...
Wireless Internet connectivity not working.
Does it recognize your wireless network?
I your wireless switched on on the laptop, most laptop have a separate small switch to swicth on/off the wireless option, indicated by a small antenna with some waves.
Does it recognise any wireless network at all?
Try connect to a hotspot or unsecured network to see if that works. Double check all settings for your own network in your router and your laptop. 1 typo in a security password can be enough to be unable to connect.
Aug 08, 2008 | IBM ThinkPad R52 Notebook
Wireless problem
Hello router_lost
I believe you are correct in your assessment that the issue is related to your router. Likely, that issue involves configuration - of your router and/or your laptop computer.
(01) Is the computer that is running Vista connecting to the Internet (via the router) using a wireless network adapter or a wired network adapter?
(02) Assuming that the Vista computer is connecting to the Internet wirelessly, please, tell us the manufacturer, model number and version of your router.
If the Vista computer is connecting "wired" and not "wirelessly" AND you have no other devices on your LAN (home network) that are successfully connecting to the Internet wirelessly through this router, then, it's possible that the router's radio is not enabled. However, if the laptop is "seeing" your router, then, of course, that isn't the case.
(03) Are you sure you are attempting to connect to the correct wireless router from your laptop?
I've seen it quite often where users will think they're connecting (or trying to connect) through their own router when, in fact, the router is a neighbor's (not their own).
(06) You can avoid this possibility by assigning an unique SSID to your wireless radio. In other words, change the SSID (wireless router's "name") to something other than the manufacturer's default SSID. (e.g. Netgear's default is "netgear" and Linksys's default SSID is "linksys", etc.)
It's best, for security purposes, not to assign a revealing SSID (e.g. "TheSmiths" or "2201YourStreetName", etc). Call it "BlueMoon" or whatever you like. Just something unique yet not revealing of your identity or location.
(07) Please, tell us the manufacturer, model number and revision of your router.
(08) Please, tell us the manufacturer, model number and serial number (or service tag) of your laptop computer.
(09) Please, tell us the operating system that is running on your laptop computer.
W/ this information, we'll be able to provide you with specific instructions for correcting your laptop's connectivity problem at home.
(10) Do you know if you have WEP or WPA encryption enabled on the router?
If you do, then you will need to enter either the router's wireless encryption "password phrase" or the hexadecimal key code password in order for the laptop to be allowed to access the Internet. You should only have to do this one time - then your computer will save the information.
If you've been connecting to free networks fine, then you've likely not been required to enter a password phrase or key in order to connect.
Please, post back here w/ answers to the questions I've asked here along with any other questions, comments, and observations you might have. We'll continue to work w/ you on this issue until it's resolved.
Thank you
BJ @:)
Apr 15, 2008 | Computers & Internet
Toshiba Satellite P205-S6287 Notebook PC Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
