Question about Microsoft Computers & Internet
Windows not starting
Hello my system is not responding even though i have started with Last best known configuration. Please help me to solve this issue all my important documents are there in the system which i have to send now.
Thks in advance
  • Jasper Dumlao May 11, 2010
    have you tried booting in safemode?
First of all goto safe mode booting and then go back to normal booting and check it.
You have mentioned as not responding.....what exactly is it doing? can be more specific on this..
Posted on Jul 28, 2008
Black screen on aspire one
Restore to Last Known Good Configuration:
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the first attempt, the backup copy is also corrupt.
Use system utility software like RegInOut after restarting windows.
Dec 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
My labtop came to a boot up screen that has the options: safe mode, safe mode with networking, safe mode with command prompt, last known good configuration, and start windows normally. i have windows xp....
Hello xderekhx716, to choose the [least] likely {Mode} in order not to "Lose any Data," you want to choose; "Start Windows in Safe Mode." If an incident 'occur' before this 'window' [Popped-Up], then you want to "Start the Computer in {Safe Mode}. This 'way if you have been "Infected by a 'Virus' or any of the Computers Configurations have been 'changed,' or "Windows Shut Down 'Unexpectedly' than Safe Mode is the 'choice,' because the; least amount" of Operating Systems, applications will be deployed at "Startup," ie. Drivers, Programs... This will 'protect' the System' from further 'damage', if there was any? You will have the opportunity to analyze the situation safely. Next, if the Computer is having 'problems' starting, or the "Operating System is not 'responding' or there is "no change, than a "message" will identify the 'still' remaining problem; "Starting Normally." Then you want to 'choose,' start Windows at the "Last Known Good Configuration" also known as "System Restore." Finally, if this was just a "simple "Shut-down?" Than, "Starting Windows Normally" is OK! Follow all the instructions "carefully" in any of the "Modes" you may need to [Choose]. I hope this information is helpful? Thanks for using FixYa, paul7of9"
Feb 08, 2011 | ASUS Eee 4G Notebook
Hello, I have a question about my computer. Well today i started up my computer and it tells me that it stopped responding or restarted unexpectedly. Then it tells me to run the computer in safe mode,...
hi,am ravi here,you can just select safe mode and run your system it will solve all system errors and will get open win xp os.after that you can restart and run it in normal mode.you wont get destroied any of your data.
Sep 21, 2010 | Computers & Internet
My sony vaio cant configure properly
Start the Computer and keep tapping the F8 key to access the Windows Advanced Options.
Select Last Known Good Configuration.
If the issue persists, you can try start up repair from the Windows Advanced Options.
If the start up repair is not present in there, you can use the Windows Operating System disc to launch it
Mar 15, 2010 | Computers & Internet
Restarting unexpectedly
I think Windows is currupted You need to repair or re install operating system using Windows CD. try to repair using Windows CD
otherwise reformat the c drive and install the operating system.
It deffinately solves u r problem
if it helps Rate me!
Jun 25, 2009 | VIA ASUS "A7V400-MX" KM400A Chipset...
Please please help
did you install any new software?
if not then please try to restore your windows installation by the restoration disk provided by your computer manufacturer.
Hope this solves your problem
Apr 16, 2009 | Samsung NC10-14GW Notebook
Media Center "video crash" after installing SP3 dhclaytonphd@msn.com
(1)The first thing I would do is download video driver from dell.com/support. (2)You can remove SP3 and see if that works. (3) If not you can Start the computer using the last known good configuration I copied this from WinXP Help and Support you should be able to restore your system. If this helps please rate me if not let me know so I can help. mysleuth
To start the computer using the last known good configuration
  1. Print these instructions before continuing. They will not be available after you shut down your computer in step 2.
  2. Click Start, click Shut Down, and then, in the drop-down list, click Shut down.
  3. In the Shut Down Windows dialog box, click Restart, and then click OK.
  4. When you see the message Please select the operating system to start, press F8.
  5. Use the arrow keys to highlight Last Known Good Configuration, and then press ENTER.
  6. If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
note.gif Notes
  • Choosing Last Known Good Configuration provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. It does not solve problems caused by corrupted or missing drivers or files.
  • When you choose Last Known Good Configuration, only the information in registry key HKLM\System\CurrentControlSet is restored. Any changes you have made in other registry keys remain.
  • NUM LOCK must be off before the arrow keys on the numeric keypad will function
Mar 11, 2009 | Dell Dimension E510 PC Desktop
My windows XP will not start
Hi See
To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER.
Will Solve
Jan 11, 2009 | E-Machines eMachines Desktop PC
Computer will not start
Choose Last Known Good Configuration. If that doesn't work, choose Safe Mode and then do a system restore to roll back your PC.
Any further questions, please use the comment box below to respond. Thanks.
Worldvet
Jun 16, 2008 | HP Computers & Internet
Computers & Internet Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
