Question about XFX GAMEPAD | GA-CP03-SK0200G (GACP03SK0200G)
Dll file hi collie! yes i have the correct driver and i already did the things that you just said (suggested) but it always ends up in an error prompt saying it can't find the xfx_ffb.dll file
You need a good grafx card not the intergrated one that came with your PC. Integrated cards can't handle rendering.
Posted on Jan 19, 2009
Aegise5dll was not found problem always come on my laptop screen hw i can get ride of this option?
Its concerning the wireless manager on your laptop. You will need to update the drivers for your wireless manager that should stop the error from appearing
Mar 03, 2011 | Computers & Internet
When trying to scan, my scanner software program comes up with "twain_32.dll" not found. My HP PSC 1350 Printer/Scanner has always worked before.
http://www.fix-all-dll-errors.com/twain_32.dll/
Just visit this site...this will help in case of missing or downloading dll's , also if dll's are corrupted or errors in dll's..!
I also registered few dll's from this site...worked in my case. :)
Dec 24, 2010 | HP PSC 1350 All-In-One Thermal Printer
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
I try to run the game, Momento Mori, on my HP 64 bit late mod laptop. When I try to start it, it says it can start because it's missing d3dx9_37.dll. The .dll is located in Windows/System32, but I get that...
The d3dx9_37.dll error is a DirectX 9 problem. It could be missing or corrupt.
DO NOT download the file from dll download sites because there could be many different reasons why this error occurs.
First of all restart the computer if you haven't already done so as the error could be a one time only issue. Most games require you to restart anyway. Do so even if you are not prompted.
Secondly, if the problem persists try reinstalling the game as it could have been a bad install in the first place.
Also you can download DirectX from Microsoft.com, search for DirectX End-User Runtime. Download and install it. This usually resolves the error.
Regards.
Jul 22, 2010 | HP Pavilion dv9830us PC Notebook
How do i remove run.dll2 from my computer?
Rundll.exe files are programs that are directly tied to the registry on Windows computers. Dynamic Link Library (DLL) files contain libraries of information used by other programs running on your computer. They were originally created in order to help computer programs run faster on the Windows operating system. When a DLL file is corrupt or missing, a Rundll error will be generated. Normally when a rundll error is generated it is related to malware.
  1. Note the process that is generating the Rundll error by examining the last file name in the error that ends in ".dll."
  2. Open the service configuration program on your computer by selecting the "Start" menu and typing "command" in the search text field. At the DOS prompt type "services:msc" and click "Enter."
  3. Select the DLL service from Step 1. Right click the service name followed by the "Stop" menu button. Exit the service configuration program.
  4. Open your computer's registry editor by typing "regedit" at the DOS prompt and navigate to the Rundll registry key by typing "Microsoft\Windows\CurrentVersion\Run" in the Search field.
  5. Select the registry key returned and in the value associated with the registry key, confirm it ends in the same DLL file name found in Step 1. If it does, single left click the value and Press the "Delete" key. Exit the registry editor.
  6. Restart your computer and the Rundll error will be corrected.
Save a tree.
Apr 28, 2010 | HP W19b LCD Monitor
Describe your Acer Aspire One PC Notebook
first boot your computer with winxp recovery disk.
then ewnter in recovery console then type in command prompt "chkdsk /r"
then press "y" then it fix error on disk.
then check.
Jun 25, 2009 | Acer Aspire One PC Notebook
My problem is I have a printer and I cannot install it because the file wiafdrv.dll on windowsxp home editon cd-rom is needed an do not have one.
Do you have a Lexmark printer? I found this dll file and many of the comments about it relate to Lexmark printer issues. Click the below link and it will download your missing dll file. I searched for "wiafdrv.dll" and there were no hits for this dll, but there was one for the dll file "wiafbdrv.dll". Make sure before clicking the link below, that this is the correctly named dll file you need.
http://www.dll-files.com/dllindex/wiafbdrv.zip?0VFiP0aMgO
Extract this file and place the dll file in the correct location as specified by the error you're receiving.
Mar 04, 2009 | Computers & Internet
Wiafbdrv.dll driver will not unzip properly with winzip
http://www.fix-all-dll-errors.com/wiafbdrv.dll/
this will help in case of missing or downloading dll's .
helped in my problem. :)
Feb 11, 2009 | Dell A920 InkJet Printer
Iwve got an alert that i missed m3plugin.dll i found the dll file and copy it to the correct file according the path but now he say that i missing antry upf
Try to register the DLL file. Goto run type cmd. This will open the command prompt. Type regsvr32 c:\enter location of .dll file\m3plugin.dll and press enter. This will register the .dll file if that is the problem.
Dec 03, 2008 | Intel Motherboard
Unable to setup printer driver fro D-Link DP-301U
I'm not able to install the printer driver Officejet 5610 when conenct to D-Link DP 301U. It always prompt for missing file such as hpzimc09.dll hpzstw09.exe, I'm using the CD proviede when I purchase the printer and also try on the installtion file downlaod from HP website.
May 22, 2008 | D-Link DP-301U (790069251979) Print Server
Video Game Consoles & Games Logo
138 people viewed this question
Top XFX Video Game Consoles & Games Experts
James Wishart
Are you a XFX Video Game Console and Game Expert? Answer questions, earn points and help others
