Question about Power Acoustik LT-980/2 Car Audio Amplifier
Alpine system in car has no sound
It shows the system is working. But the amplifier in trunk has no light on. No sound from speakers. I checked fuses near battery. They seem to be good.
    Scholar:
  • 82 Answers
Your amplifier has no power because it has no supply, it is maybe because there is an open circuit in your wiring. The voltage from your battery does not produce current in your amplifier because it is not connected. In other words, Somewhere in the circuit in your car amplifier is open or not connected. Obviously from the amp and speaker has no connection and the fuses are ok. Friend the problem maybe is in these, try the following:
a) the switch in you amplifier might be in trouble. Try to see the switch if it can perfrom the desired operation, in other words, do the contact point is ok?
b) if the contact point of the switch is ok, then try to see the connection from your amplifier to the battery.
P.S. If this be of help, please rate.
Posted on Jul 28, 2008
Amp light on my MPR-M1000 keeps flashing
HI,
Disconnect the speakers fist. then check the amplifier light flashing or not. If not then then any of the speaker is faulty. If the amplifier's Light flashing even after removing the speakers then any one of the amplifier stage inside the amp is faulty. By blinking it shows that its in protection mode.
Normally the out put transistor can become faulty. Which can lead to the amplifier to protection mode to avoid damages to the speakers connected to it.
If its not speakers then you should consult the Alpine service centre or any professional technician. Because repairing such type of amplifier should done by a very qualified person. If not it will lead major defects which will make the amplifier scrap.
Ajin
Apr 27, 2012 | Alpine Car Audio & Video
My mrp m650 alpine amp power light is on but no sound. it works if i hook it to other vehicles but not in mine.
Check your speakers and speaker wires to make sure you have no shorts or grounds. Not knowing what vehicle you are putting the amp in, there is also a possibility that there may be a stock amp in the vehicle. If this is the case, you may have to rewire the speakers and bypass the stock amp.
Feb 27, 2012 | Alpine MRP-M650 Car Audio Amplifier
No sound from amp when amp is powered up, whats wrong? Alpine m-1000 wih alpine deck. Was told something about resetting it but don't know, please help?
There is a number of things that can cause no sound from the amp.
Check to make sure your RCA's are plugged in to the amp.
Make sure the ground and remote are not touching on the amp.
This will cause your head unit to gray out in some areas.
Verify, your subwoofers are in working order.
Test another pair of speakers on your amp to make sure.
If those speakers work, your subwoofers are fried or have come unhooked inside your subwoofer enclosure.
Make sure you have not set the head unit to Surround Sound if you have a DVD player in your vehicle.
This should be set as passive.
Make sure your gains aren't turned down on the amp.
MAKE SURE YOU DIDN'T BLOW A FUSE UNDER THE HOOD.
Even if there is a light on the top of the amp, the fuse might have blown.
Make sure a fuse on the amp didn't blow. This will in some cases cause the amp to go into protect and no bass.
Jul 27, 2010 | Alpine MRD-M1000 Car Audio Amplifier
Hi ive got a alpine mrp-m1000 it lights up no sound was woking fine in the car didnt use car for 3 months then i wouldnt work all wires are fine and so is the sub please help
If your not getting any sound make sure the sub input is in the right spot on you radio. if not check the speaker wires on your harness
Feb 14, 2010 | Alpine MRP-M1000 Car Audio Amplifier
The radio doesn't sound right
hello their, frist of all is the amp in the truck
running any woofers?
1. the alpine radio how old is it 2005-2009 ?
shuld have plenty of power
to pay the facory speakers and even up grades to a certain level.
try finding what that amp is playing ..
know if that amp palysyour system just needs to re-just!!
Mar 10, 2009 | Alpine Car Audio & Video
No light on Alpine MRP-M1000
Ok. Have you check the Ground and the Power connection.
Jan 25, 2009 | Alpine MRP-M1000 Car Audio Amplifier
Sony Xplod 1200w
Either the speaker is shorted out (blown), or the output transistors in the amplifier are bad. Try hooking up another speaker to the amp. If it plays, the amp is good. If not, then the amp is bad.
May 22, 2008 | Sony XM-1252GTR Car Audio Amplifier
Blown fuses
This is a sign the you have poor voltage regulation. Which may mean that you are taxing the electrical system of your vehicle. I would suggest you adding a secondary electrical supply for you audio system. This can be done by adding an extra alternator and voltage regulator and battery supply. This will allow you to drive your audio system without having it (power supply) split between the vehicle and the audio system. The fact is your system is drawing to much current for the unit and your vehicle. You are blowing the 20-amp fuses which means the the amp is creating a currnet draw which is past the rated value of the fuses, which if done too many times could damage the power amp components in the unit. I would also check the ohmage reating on the speakers connect to the unit since you may have the wrong impedance which may also cause excessive current draw and actuate some sort of overcurrent protection.
Aug 31, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine MRV-T707 Car Audio Amplifier No Sound
disconnect all power (15min) try again with different speaker to see if sub is dammage.
Aug 22, 2007 | Alpine MRV-T707 Car Audio Amplifier
LED Light green but no sound.
disconnect all power cables first then short between G&P G&R try again with only one speaker at a time.
Aug 21, 2007 | Alpine MRV-T707 Car Audio Amplifier
Power Acoustik LT-980/2 Car Audio Amplifier Logo
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
