Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Menu flashing hey. my menu display keeps on appearing and disappearing continously. wt is the problem? Karim
    Genius:
  • 1,030 Answers
Here at the shop i have seen this a few times... generally by that i mean 85 percent of the time it will be the front panel or the front buttons. a small cuircit board which i replace. then there are times that i have seen the small cuicit board known as the IR (infra red sensor) bad then there was onnce it was the small signal board. the first to any one can do the last requires specal equipment and is ussally done by a tech.
Posted on Jul 28, 2008
My bosch frontloading washing machine when turned on there is flashing of spin and pause/off butons. we can't turn on the washing machine can you please tell me what the problem might be
Try pressing these buttons for 5 seconds, it will unlock.
OR
Press the "menu" button until you see"CHILD LOCK: ON" appear in the display. (if nothing is pressed within 10 seconds following this the menu will close and it will default to program in the display)
Once you see what I just mentioned in the display press the "select" button until"CHILD LOCK : OFF" appears in the display.
Finally by pressing the"start/pause" button the key symbol should disappear confirming you have successfully unlocked..
Pl click if helped.
Apr 28, 2013 | Bosch Washing Machines
My machine show a 01 and a flashing key I try to do hold a button for 5 sec to deactivate but time tab it's not reacting with at is the prob
Your washer is in the "child lock" mode, hence it won't allow any program. Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following this the menu will close and it will default to program in the display. Once you see that in the display, press the "select" button until "CHILD LOCK :OFF" appears in the display. Finally by pressing the start/pause button the key symbol should disappear - confirming you have successfully exited the child lock program.
Pl click if helped.
Mar 14, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Hey my song ericsson w700i is not starting, when I power it on, it start and the sony ericsson symbol appears but then a white blank screen keeps appearing and disappearing.
Give your phone to Sonyericsson Customer Service center, They will Flash ur Phone with New software.. after that your phone will working fine...
Sep 08, 2012 | Sony Ericsson W700i Cellular Phone
Im trying to adjust my philips lcd but menu says "osd main control is locked" how can I unlock it?
In order to resolve the OSD menu locked error:
1. You must reset the on screen display in the menu.
2. Hold down the Menu button for at least 60 seconds.
3. A menu list will appear on your monitor screen.
4. Using the adjust button, press the arrows to enter the menu.
5. Scroll down to the Reset section.
6. On the right side of your screen, you will see an alternating Yes/No choice.
7. When the Yes message flashes, press the Ok button.
8. The menu should be reset and the flashing OSD control message should disappear.
Apr 12, 2010 | Philips 190B6CB/27 19" LCD
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
All of the icons from the screen disappeared!
try to reboot your computer into safe mode.
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Then click start
click run
type in msconfig
uncheck everything under the startup tab except your antivirus
and reboot
Jun 05, 2009 | Computers & Internet
PANASONIC 1000 MICROWAVE OVEN
Hello Karim,
I went to the Panasonic website - - (http://www.panasonic.com/)
Clicking on Commercial Food Service - Customer Service links, I got
http://web1.panasonic.com/food_service/cmo/customer_service/f_codes.html
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Dec 30, 2008 | Panasonic NN-S251 Microwave Oven
Running windows xp media center edition and when displaying "All Programs" the programs are listed in order of installation, as expected. However, when right clicking on the "All...
Hi
Try downloading style XP to modify the behavior of your taskbar...Not only will you be able to do the sorting But you can even modify its appearance and transparency as well....
Oct 16, 2008 | Computers & Internet
Mitsubishi wt-42311 tv wont stay on
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Mitsubishi WT-42311 42" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
