Question about Mitsubishi WS-55807 TV
Have Volume but no video on TV. Any recommendations?
Hi, our YouTube.com on our big TV Flat size 51' and using volume and doesn't work volume sound, not working. Need fix it and sound turn on, please.
Volume on TV or receiver or the volume slider within the video?. It seems of one of these does not work you can use one of the others.
Dec 30, 2014 | YouTube Videos
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | RCA Audio Players & Recorders
HOW CAN I HOOK UP HOME THEARTER SYSTEM TO MY TV
Assuming (since you don't identify them) your RCA has at least one available analog stereo input and your TV has a analog stero-only output, just connect them with RCA cables, set the TV's output volume (if it has menu item for it) to FIXED so theTV volume doesn't affect the output, select the input on the HTS and you're good to go.
Another way might be to take the TV-related audio from the cable box straight to the HTS in whatever manner is the best quality. Digital would make mulitchannel audio possible.
Or name the devices involved, find the manuals and read up on your applicable options.
The video out side of a receiver only REQUIRES a simple video out connection so you can see the On Screen Display for managing it. Most manuals (which you DO have, right?) also recommend running all or some video sources through the receiver to the TV but I don't bother conencting video to my audio electronics or audio to my video electronics as it wastes cables, adds connections which could fail and adds virtually nothing to either medium.
Feb 04, 2011 | RCA Audio Players & Recorders
No volume coming through. I have a Panasonic tv
What sound from what source? Is the TV the source of the sound ? If so, why? The best TV-related sound would be had from the cable, dvd, bd or whatever else it is showing. Your TV could be the reason you cab't hear it.
What still works? FM? CD? Have you cracked the manual to see what it recommends? How about running through the basic speaker setup again to see how that works out.
May 02, 2010 | Onkyo TX-SR604 Receiver
Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Apr 30, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
My older Yamaha receiver has lost volume on the TV output.
if TV outputs are okay.Then simply connect TV into another input on reciver, AUX,TAPE,VIDEO ETC...if problem persist then output from tv is the problem..check settings on tv
Jul 29, 2009 | Yamaha RX-V2400 Receiver
Dell 32 inch LCD Tv volume and menue problems
your main board is not communicating with the tv. it may be on the breaks of going bad, or simply needs a firmware update. questions, email me
May 24, 2009 | Dell W3706MC 37 in. LCD HDTV
Mitsubishi WS-55807 TV Logo
52 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
