Question about Toshiba Satellite P205-S6287 Notebook PC
Router and Modem
How do I know if the wireless router I'm looking at will work with my DSL modem?
  • 928 Answers
Any wireless router will work with the DSL modem as long as the modem has an ethernet port on it.
Posted on Jul 28, 2008
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
My Belkin wireless G router does not seem to work any more. If I connect my router to my DSL modem, I am not able to make a connection to the internet via the router to my iMac. However, if I connect the...
So if you connect the computer directly to the modem , it works .
That means your modem is working properly. Your ISP is DSL connection. Now connect the modem to the router and the computer to the router. Open the router xet up page and change the settings of the router according to the type of connection you have.
There are 2 types of connection in DSL.
DHCP and PPPOE .
Click Here for step by step instructions
Feb 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a siemens 4200 adsl modem i had a net gear modem before and that was not working with wireless internet and now this modem wont let me connect wireless either only with the ethernet cabel. help!
Hello Mate,
the siemens speedstream 4200 is a DSL modem/Router which doesn't have wireless connection. So even tough if you have a computer equiped with a wireless adapter, you will not be able to connect wirelessly because the siemens 4200 doesn't act as wireless access point.
You may need next time to check first if the modem/router to buy support wireless (wifi g or n) and make sure that it's not only a modem, it should be also a router.
i attached here some references for you from the top brands:
1. Linksys DSL modem/Router with wireless N: http://www.linksysbycisco.com/MEA/en/products/WAG120N
2. Linksys DSL modem/Router with Wireless G: http://www.linksysbycisco.com/ANZ/en/products/WAG54G
You can find other brands as Dlink, Netgear ...
Best Regards,
Oct 29, 2009 | Computers & Internet
If I have a wireless router do I still need a modem?
It is depend on which type of connection cable your internet service provider.
You don't need modem if in your router ADSL port and your ISP gives you ADSL but if on wi fi router there not dsl port and your ISP gives you dsl cable then you need modem.
Let me know if you need more assistanse.
Thanks.
Sep 11, 2009 | NetGear WGR614 Wireless Router
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Belkin router
I just worked on one of these today. Try this and see if it helps.
1. Unplug your cable or DSL modem and your wireless router
2. Plug back in the cable or DSL modem and wait for the internet to successfully connect (watch the lights).
3. Plug the wireless router back in again and wait for it to connect (again, watching the lights)
If this doesn't work, make sure you have the equipment plugged-in in the right order.
cable or dsl signal goes to modem ==> modem plugs into wireless router ===> computer plugs into wireless router.
Feb 02, 2008 | Belkin (F5D7230-4) Router (587009)
Internet service to service routing
you cant use a cable modem and a dsl modem at the same time as its a dsl dialler and a router and a cable modem works differently, all the settings wont match, you will have to purchase a seperate router or cable modem/router
May 13, 2007 | 2wire (1000-400108-001) Router
Toshiba Satellite P205-S6287 Notebook PC Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
