Question about Toshiba Satellite P205-S6287 Notebook PC
Wireless Routers Does netgear make a good wireless router? Would you recommend netgear or linksys?
  • 928 Answers
It would be better with Netgear as the setup is easier but I go with Linksys because of the price.
Posted on Jul 28, 2008
Which are the best Wireless Routers under $200?
Some of the best wireless routers available under $200 are:-
? Linksys WRT1900ACS Dual-Band Wi-Fi Gigabit Router
? ASUS RT-AC68U Wireless AC1900 Dual-Band Gigabit Router
? TP-Link AC1900 Wireless Dual-Band Gigabit Router
? NETGEAR AC1750 Wi-Fi Cable Modem Router
? TP-Link Archer C7 AC1750 Wireless Router
You can check and compare these wireless routers at:
Best Wireless Routers 2017 Reviews and Comparison
Jan 07, 2017 | Best Computers & Internet
Home wireless internet
All routers are good routers however Linksys routers are really good routers and usually are a good price you can connect up to 8 wireless devices on most routers including your wireless phone. Also the range is usually around a 100 yards. however like I said most routers allow you to connect many wireless devices, but here is a list of good routers.
Linksys, Netgear, Dlink, Asus Hope this helped
Jul 15, 2013 | Computers & Internet
I have an apple router. Periodically, I cannot connect to Internet. I must unplug router and modem and replug. Things can be fine for days, then it happens again. My cable provider has checked all lines. I...
It's a common problem with wireless routers, especially with certain ISP's, there's several theories about why this happens including cheap parts and software on the routers but it can be much worse if it's over a cable connection. Possibly because the MTU is higher on cable networks than wireless ones. This issue doesn't seem to affect wired connections to the routers as much. ie you may still get a working wired connection even if the wireless isn't working.
Certain makes are known to behave this way, with certain ISP's. eg in england there's a cable company called virgin media, belkin routers really don't seem to like them, but netgear seem to work much better, which is probably why virgin recommend netgear and will only supply netgear routers themselves.
Try changing the channel id if it's wireless, as there may be a lot of interference around you and this may or may not have a bearing on this issue. If that doesn't help then ask your isp what make they recommend as they should have an idea of what will work best, at least the tech support dept should.
In my opinion the best makes of routers are netgear and linksys. I also like belkin although they aren't as good as they used to be, and as mentioned can suffer from this problem quite badly in some cases. As you are with a cable
You will never completely eradicate this problem, all wireless routers will need resetting now and again, but it should be weeks or preferably months between each time. Cisco routers may be more reliable but they're business routers and are very expensive, and probably a bit more complicated to setup.
ps. I used to work for virgin media as tech support.
Jan 18, 2011 | Apple Computers & Internet
Need help hooking up wireless (netgear) adaptor 2 bed room computer.We have a linksys router, but forgot password
You will need your password.
Uninstall Internet Programme via Control panel
Hopfully you have the Setup CD.
Insert CD follow online instructions. Recommend you use NI number?
After thought, the Puta in the bedrom, I asume it has wireless adapter?
Dec 26, 2010 | Linksys WRT120N Router
So I have a little problem. I'm trying to find out how to connect 2 wireless routers together from across the house. The internet side is connected to a Linksys wireless router (WRT54G). This is located in...
you need a wireless ethernet bridge(like wet54g/wet610n) which will grab signals wirelessly from u're primary router wrt54g,& then a ethernet cable from wireless bridge will be connected to one of the lan port of u'rs netgear router(otherwise u will not be able to do file & printer sharing between 2 routers)Remember,the ip address of all 3 devices shold be of same class.
Jan 02, 2010 | NetGear WGT624 Wireless Router
I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
Oct 06, 2009 | Linksys Wireless-G WRT54GS Router...
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website.
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Connecting another router
i would'nt recommend it, theres no need for two unless you have mote than 4 hardwired pc's and 8 wireless, especially if they are both modem/routers, you cannot use two, only one modem/router and one router
Sep 15, 2008 | NetGear DG834G Router
New netgear 624 router and having trouble keeping it connected
You can try changing the wireless network name or ssid, change the wireless channel to 11 and enable WPA as the wireless security.Just open IE then type on the address usernama is admin and password is password then do the changes there.
Jun 16, 2008 | NetGear WGT624 Wireless Router
Toshiba Satellite P205-S6287 Notebook PC Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
