Question about Compaq Presario 700 470024-192 Notebook
Playing DVD's When I go to play a DVD it won't play because it's in the wrong region and says I have to reset it. But then it won't let me reset it when it tells me to reset it. It says I'm in region 8 and I need to be in region 1.
    Problem Solver:
  • 11 Answers
Do a Google search for "reset dvd region" and you will find a variety of software solutions to allow you to either reset the region or bypass it altogether.
Posted on Jul 28, 2008
DVD says wrong region ?
hi Nigel.
Region codes prevent playback of DVDs in other geographical regions. If you receive a region error while playing a DVD with RealTimes, this means that the region code of the DVD does not match the region code of the DVD drive. ... You can play Region 2DVDs only on a DVD drive that is set for Region 2.
Region errors when playing DVDs with RealPlayer - SUPPORT
https://customer.real.com/.../204041263-Region-errors-when-playing-DVDs-with-RealPl...
How do you change the region on a DVD?Click Performance and Maintenance, and then click System. On the Hardware tab, click Device Manager. The DVD Region tab might not be available for all DVD drives. To configure your DVD drive to play discs from other regions, select a geographic area from the list of regions.
(you could try this link but what ever it tells you to do you do so at your own risk.)
Make Your DVD Player Region Free in Seconds
Nov 18, 2017 | Televison & Video
My sylvania dvd player says wrong region when i put n a dvd..but it will play cds
Your cd's may be region free but dvd's unless stated as region free will only play on a player that is capable of playing the region shown on the dvd unless you have a region free dvd player.
Dec 27, 2012 | Televison & Video
Wrong region DVD player won't play a disc
Can,t be done with the one you have,
Nov 10, 2012 | Philips Televison & Video
Playing a dvd from another region on Yamakawa dvd -275 dvd player
You may have to go into the Menu options and select a diff. region
Apr 19, 2010 | Yamakawa DVD-275 DVD Player
Have dvd that say check regional code how do i do this ?
sounds like you have purchased the wrong region coded dvd`s when you bought them from amazon? if you are in the US you can only play Region 1, Europe is Region 2 and so on. Unless you purchase a mlti region machine which is obviously not what you want to do then the only other play of playing the wrong region discs is to buy a cheap dvd player which has "DivX" compatability which will play any region for you.
Sep 07, 2009 | Zenith DVT216 System
I have a region 2 samsung dvd player. All of a sudden the following message displays: '' Can not play disk. Wrong region code'' We have been playing the dvd for more than 1 year. What is the problem? Same...
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Jul 03, 2009 | Samsung DVD-P181 DivX DVD Player
Trying to play dvd but says wrong region soneynhv-dx350ab?
Hi, if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution. Mike @ Compurepair.
Jun 12, 2009 | LG RC897T DVD Recorder/VCR Combo
No disk
Try playing Different DVDs, Second Make sure which Region Disk your playing is it Region 1 or Region 2, If your DVD player is Manufactured in USA it plays only Region 1, If its manufactured in UK it plays only Region 2, If still you face same problem Use Lens Cleaner, If still you face same problem do Reset.
To Reset Dvd player, Remove DVD from Dvd Player, Unplug Power chord from Walloulet for 15minutes so player goes to Defult Factor Settings, Then plug back again Power chord. Turn on Dvd player insert DVD, It should Play or else Claim Warranty.
Nov 29, 2007 | Curtis DVD8017 Portable DVD Player
Movie does not play
Nov 14, 2007 | Curtis DVD8017 Portable DVD Player
Compaq Presario 700 470024-192 Notebook Logo
67 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
