Question about Toshiba Satellite P205-S6287 Notebook PC
Wireless Router If I use a wireless router to get the internet for my laptop, can I still use wi-fi at locations such as Starbucks?
  • 4,889 Answers
No. If you are talking about catching wi-fi signals where they are available. What you need is a wi-fi card and a wifi catcher software.
Posted on Jul 28, 2008
  • 928 Answers
Yes you can, you just have to connect to the network wherever you are and provide the password for that location if it has security.
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
Wi-fi not working
If you are connecting to someone's wireless network without theie permission then they most likely decided to secure their wireless network.
You can connect to a free wireless network at locations such as the airport, Macdonalds or Starbucks etc. These are ususllly unsecured wireless networks.
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 09, 2012 | Fujitsu Siemens Computers & Internet
My router is not sending the wi-fi signal, i already reset it more than 10x and unplugged it and unplugged my modem , restart or turn off my computer i did the whole run> ipconfig ****, still nothing...
Got any other "wireless" device that you can try, such an iPod Touch, to try to pickup a signal from your router?
Does your laptop have a switch or slider or FN-key-plus-some-Function-Key-1-thru-12 to disable/enable the laptop's wireless adapter?
If you take your laptop to another location with "free WiFi", such as MacDonalds or Starbucks, can you pickup their wireless network? If not, then the problem is _NOT_ your D-Link router.
If you use your desktop to connect to the web-server "inside" the router, does the wireless transmitter on the D-Link show as "disabled" or "enabled" ?
Jul 18, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
I cannot connect my IPOd Touch to the internet to download music . I need wi-fi connection. I already have internet service. What is wi-fi and how do I get it?
Wi-fi is wireless internet. Wireless internet is aquired via a router that supports wireless internet. The router is connected to your modem which supplies your internet.
Sep 29, 2009 | NetGear DG834G Router
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
No Wireless Connection
Let’s check the Wi-Fi card on your PC. Go to "Device Manager" and look if any yellow or red alerts are being displayed under the Network Adaptors. If not, make sure the Wi-Fi card shows up under Network Adaptors. To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column.
If there is an alert, double click on that device to determine the problem, i.e.… device not configured, cannot start this device, etc…
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 27, 2008 | Dell Inspiron B130 Notebook
Router?
You need to be in a location near a wireless router.
If you go to say Starbucks they would have their own wireless router. Some places like this will put a password on the wireless network. You may have to ask them for the password. Although, most of the time it is open access.
Jul 28, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite P205-S6287 Notebook PC Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
