Question about Refrigerators
GE Fridge: PSS26SGPA SS Model
I couldn't find the GE model: PSS26SGPA SS.
My fridge is not cold enough. I tried the folllowing
1. Change *Freezer temperature* to -1 and it automatically jumps to 14
2. Change *Refridgerator temperature* to 37degrees(recommended) and it automatically jumps to 44
Help!
Kind Regards.
  • Call Me Jul 30, 2008
    Thanks for correcting me..I was under the impression I was setting the temperature where as it was merely stating what the current temperature is...
  • Anonymous Mar 21, 2014
    fridge and freezer temperature is dropping too low and is inconsistent.
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Posted on Jul 30, 2008
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
Why doesnt the refrigerator and freezer not get cold enough?
You need to check a few things -
1. settings for the temperature are not set too low. Not cold enough.
2 there is no leakage through the door seals.
3. there is not too much ice formed inside the freezer walls. Needs defrost.
4. the fridge is not overloaded with stuff - not enough capacity to cool things.
5. Not enough free space behind the fridge to allow air movement for coils to cool
Please provide more details of the problem if above not helping. For example model number, is the problem happening both in freezer and refrigerator settings. Get a fridge thermometer and monitor temperature in both sections. should be 4 deg C in fridge and -18 deg C in freezer after stable operation.
Apr 23, 2014 | GE Refrigerators
My ge refrigerator model pss26sgpa is not cooling in fridge or freezer
make sure the condensor fans are clean they are prob. full of dust. bottom rear of unit.
Apr 18, 2012 | GE PSS25NGM Side by Side Refrigerator
GE fridge/freezer on but no cold air
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
Mar 07, 2010 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Jan 19, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
1,197 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
