Question about Philips GoGear HDD6330 MP3 Player
All files deleted
One day my go gear 30gb wouldnt turn on so i put it in the charger. i came back a couple hours later and it was fully charged. but when i went to select a artist it said [ list empty] . which is strange because when i hooked it up to the computer and searched my device through windows media player it showed that all my music was there . why is it doing this ?
  • 476 Answers
This problem is caused by a corrupt database file. When the player starts it doesn't scan the hard disk, it reads the database file instead. Anything that it doesn't find in the file, it ignores. This means that your tracks have not been deleted, but the player can't 'see' them.
You will need to repair the player using the Philips Device Manager. This will format the player and reload the system files.
The latest version can be downloaded here:
https://www.p4c.philips.com/cgi-bin/dcbint/sget?url=/mprdata/060924/060924042328_15781.zip&ofn=HDD6320_6330_DM_WEB_ENG.zip
If you don't have the tracks on your PC, you can copy them off the player as follows:
Connect the player to the power supply and the PC.
Press and hold [POWER ON] & [VOL+] to reset the player.
When the player resets, quickly release the buttons, then press and hold [VOL-]
The player should register as either Removable Drive or GoGear, and a drive letter eg. e:
Once the player has registered on the PC, release the [VOL-] button,
You can now use the player exactly the same as a hard disk, and drag & drop the tracks to you PC.
Restart the player, use the repair function of Philips Device Manager to restore the player, and re-load the tracks as normal.
Posted on Jul 28, 2008
Blackberry storm battery won't charge and device won't turn on.
Hi! My phone had exactly the same problem a few days ago! I got a new battery - it worked fine for a couple of days and here we go again... It is dead! Please let me know what you did with your phone! I have a new BB curve! Thank you!
Jul 14, 2010 | RIM BlackBerry Pearl 8100
Nano dead. Will not turn on. It was fully charged.
It's broken. Google "iPod repairs" in your country and they might be able to replace it. Otherwise you can get an exchange unit from Apple. Take it to your nearest Authorised Apple Service Centre and they will get it exchanged in a couple of days. Unfortunately this might cost almost as much as a new one.
Nov 03, 2009 | Apple iPod nano
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
Nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
My lg vu was low on battery so i plugged it in. i came back to it an hour later and it wouldnt turn on. it hasnt turned on in 6 hours. help
You might have discharged your phone instead of charging it. Try taking the battery out, putting it back in, and plug it back into the charger. Make sure your charger is plugged in a normal outlet, and not 1 that needs to be turned on...
Nov 23, 2008 | Cell Phones
Ipod video 30GB model a1136
All you can really do is make sure the iPod is fully charged before watching.  Video files require more system reosurces than music files, so it is very possible that it will run down in a couple of hours or less. There are no longer-lasting batteries that can be used with this particular mp3 player.
Sep 14, 2008 | Apple iPod MA446LL/A MP3 Player
Memory Dump/ Not Turning On
first prove the nod32 antivirus for see what is the situation of your memory. after this write for indicated of stay of your memory.
Sergio
Mar 16, 2008 | Toshiba Gigabeat S30 MP3 Player
Wont turn on
Please check the charger connector for dirt, if possible take an old toothbrush and clean with alchohol, let it dry and refix everything. should work.
Jul 23, 2007 | Sony Ericsson K610i Cellular Phone
Lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
Not exactly a solution. I tried leaving it off overnight and tried it several times after removing and inserting the batteries. I also cleaned the contacts with contact cleaner and a Q tip. It did not fix it. But I just left it off for 2 days meaning to go to the Verizon store and get it fixed or replaced. But I turned it on now and it fixed itself! Model VX8300. Maybe the contact cleaning did it but it had to dry more. You can use a Q Tip dipped in a cup of water with a teaspoon of Mr.Clean. But then rinse it with a water wet Q tip and then dry it with a paper towel. I used contact cleaner.
Dec 06, 2006 | LG VX6000
Philips GoGear HDD6330 MP3 Player Logo
83 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
