Question about LG WM2688HWM TROMM SteamWasher
LG front loader te code
Flashing "te" code . anything we can do ?? or is this no washy til fixed ???
  • 1 more comment
  • tacorob Feb 17, 2009
    I HAVE A TE PROBLEM CODE THE COMPANY CAME & CHANGED THE THERMISTOR 3X & BOTH CONTROL BOARDS & I STILL GET THE TE CODE POPPING UP WHAT CAN I DO
  • Anonymous May 18, 2009
    I had the te error and the tech came out to fix it and didn't know that they were stacked. he said he punched a series of buttons to reset the computer. It has been working fine.
  • tacorob May 11, 2010
    thank you i know i need to change the thermistor the last one was blown does any body know the EXACT OHMS READING IT IS SUPPOSE TO GIVE at 32 or 70 degrees F
    the factory said around 10000 ohms but that was not exact
    what would cause a thermistor to blow
  • 4 Answers
A "tE" error code is more than likely the "thermistor" as CoolTech stated but fortunately it is not that difficult to service and doesn't require a technician (warranty expired for me, consider this for your own situation). It supposedly can't be serviced by untrained individuals (thus the directions to call for service) but the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing. I removed mine after getting a "tE" error...cleaned and replaced...no problems since! No screws needed to be removed. My thermistor is a small, round, black rubber grommet with the metal sensor pushed through the center. I removed the entire grommet. It easily pops back into place. The face of the grommet and sensor appeared to have buildup from hard water which easily came off without the use of cleaners.
Posted on Jun 02, 2009
  • Mikesrib Dec 21, 2011
    Good info, but I can not locate the thermistor. I have the back metal plate removed.
The themistor is a resisitive probe found at the bottom of the washing drum next to the heater connection. It fails and is not a matter of cleaning but replacement. There are simple service manuals availible online but the are simple and you must have some common sense in order to follow them. You must remove the top of the machine then the control panel and the the front of the machine in order to reach the part on the wm2688hwm. I would suggest ordering the part and having it in your hand first before tearing the unit apart to make reassembly easier. I purchased mine through Sears Parts & Service. (only took 45 mins talking to an east indian named CHAD). Tear down takes appox 30 min. with beer breaks and reassembly takes more if you wait a week for the part. (There is everyone confused yet)(Call for a service Tech if you are)
Posted on Jun 23, 2009
I had this problem on my lg steamwasher wm2688hwm.
I had to remove the top panel of washer and disconnect all wiring clips and tubes from the off white rectangular plastic box monted in washer towards the top left. Then i took the screws out of the thermostats and pulled them out and cleaned them. What i found was that they had all been scaled over probably by hard water. Then i took the rubber cap off box filled it with water and shook it up and flushed it out. put back together and works just fine now.
Posted on Jan 27, 2009
  • 489 Answers
Te error code means the thermistor needs to changed.  You will need to call a qualified LG technician to resolve this issue.  Sorry, no washy till fixed.
Posted on Sep 29, 2008
WHAT DOES A UPSIDE DOWN FE CODE MEAN ON A WM2277HB LG WASHER FRONT LOADER
I think it is actually a 'tE" error code. Thermistor error. Pretty easy fix. And under $10 part. Repair videos exist on YouTube, repairclinic.com or appliancepartspros.com. I would suggest that you look at videos and see how they all suggest you do the repair. Top off, control panel off, front off. Fairly complicated but very doable. If you get the part and study the parts diagrams, you can do the part replacement by turning washer on its side and do replacement from underneath. Takes a little feeling around but much easier.
Feb 16, 2017 | LG Washing Machines
LG washer front loader what should be the ohm reading test good or bad for the thermistor
A thermistor varies its resistance according to temperature. As long as it is not showing infinity or extremely low, we need to know what the make and model are.
Jan 19, 2017 | LG Washing Machines
I have an washe - LG Tromm model # WM2277HB - and I am getting the error code te. What part do i need to repair this problem?
'te' on LG's normally means Temperature Error- a heating element problem. Sorry but I suggest you need to call out a service engineer to attend to it ;-0(
Good luck,
John C
Mar 05, 2011 | Washing Machines
LG wm2487hrm Washer not draining water. tE flashing. I drained water out of front and ran 2nd cycle same issue.
tE is a thermister error. It is a temperature sensor at the bottom front of the washer. tE can also be caused by a heater error. Some models have a seperate thermister, some incorporate it with the heater. It is very difficult to replace without taking the front off the machine.
Jan 25, 2011 | LG WM2487H Front Load Washer
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Jan 05, 2011 | LG WM2487H Front Load Washer
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Code error te
According to the manual, this is a control error, more than likely a sensor such as a thermistor. Call for service.
Jul 06, 2010 | LG WM2688H Front Load Washer
LG WM-2277HW will stop at the rinse cycle and flash te code. Manual says to unplug and call tech. Is there anything else that can be done?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | LG WM-2277HW Front Load Washer
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
978 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
