Question about Cisco 7912G IP Phone
Can't remove DND off display
Someone has hit some wrong numbers on our Front end phone and now we have a DND abbrevation on the display and the phone doesn't ring. I've tried *04 and dial and than hang up, but still can't remove DND. I thinkl it means Do No Disturb. Can anyone help?
  • 3 Answers
Press the [world] setting button, then choose settings
choose call preferences.
change DO Not Disturb to NO
press save (middle button)
press back
press exit
johanvt
Posted on Aug 26, 2008
How do i change the time on my phone
Try this: • PRESS PROGRAM • DIAL ** • DIAL 1234 (SYSTEM PASSWORD) • DIAL 000 (DATE AND TIME PROGRAM NUMBER) • PRESS THE NEXT KEY • ENTER THE YEAR • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY UNTIL DESIRED MONTH IS DISPLAYED • PRESS THE ARROW (FWD/DND) KEY • ENTER THE DAY OF THE MONTH • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY UNTIL THE CORRECT DAY OF THE WEEK IS DISPLAYED • PRESS THE STORE KEY • PRESS THE NEXT KEY • ENTER THE HOUR • PRESS THE ARROW (FWD/DND) KEY • ENTER THE MINUTES • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY FOR AM OR PM • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY FOR A 12 OR 24 HOUR CLOCK • PRESS THE STORE KEY • PRESS THE END (HOLD) KEY • PRESS THE PROGRAM KEY TO EXIT PROGRAMMING
If this helps you, please rate. Thank you
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
Phone display shows DND is active however phone still rings. How do we remove the notice?
Using the soft buttons at the bottom of the display, click the last button on the right (More). This will provide another set of options. The third option from the left should say "DND". Press the soft button below this option to turn off DND.
Aug 17, 2010 | Cisco 7940 IP Phone
When I have my DND on or am on a call, I still
You have the button wrong. If DND is on, the phone will not ring.
Apr 06, 2010 | Avaya Corded Phone avaparp18d
How do I divert calls to a mobile number and then undivert calls
pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
What 2 does it turn on the call forwarding feature
. and 0 turns off forwarding/do not disturb functions
theres 5 different functions after you press FWD/DND
0: turns FWD/DND off
1: put the phone into Do Not Disturb Mode
2: call forwarding
3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
and lastly 5: Busy/No Answer- does both function 3 & 4
i hope i've helped
, Cameron
Jan 22, 2010 | Panasonic KX-T7630 Corded Phone
Deactivating Do Not Disturb command
I loosely followed Solution #2's answer. If you pick up the phone, the display screen will show options above each of the 4 'arrow' buttons. The one to the far right, for me anyway, showed something looking like this: >>>
I hit it and it showed a number of options, one being "DND". Hitting that deactivated (or activated) DND on the phone I was currently on. That solved the problem for me.
Jul 27, 2009 | NEC Dterm DTP-2DT-1 Phone
DND causing line to go busy when on call for new incoming callers
Please contact your local NEC dealer and have them program the phone to go to voicemail when in DND or when Busy
Mar 20, 2009 | NEC-1090021 DSX 34-Button Backlit Display...
Cisco ip phone 7940 does not ring for incoming calls.
It sounds like you have enabled Do No Disturb accidently. This can be turned on and off by pressing the DND softkey button along the bottom of the LCD display. You might need to press the 'more' softkey to display all options.
Jan 27, 2009 | Cisco 7940 IP Phone
How do you remove the dnd from the avaya 12 button phone. all calls are going straight to voicemail
There should be a button your phone that is lit green. Press it. It should go off.
OR, you can try to hit "FEATURE 01"
Dec 02, 2008 | Avaya MLS 12 Button Non Display Phone...
Date & Time
Press PROGRAM + ** + User Programming Password (default is 1234)
Press 000
Press NEXT (Sp-phone button) : The date will be displayed.
To change the DATE (or you can press next again to go straight to change the TIME)
Enter the year (last 2 digits)
Press --> (FWD/DND button)
Keep pressing SELECT until the desired month is displayed
Enter the day
Keep pressing SELECT until the desired day of the week is displayed
Press STORE
To change the TIME
Press NEXT (Sp-phone button): The time will be displayed.
Enter the hour
Enter the minute
Press Select for AM or PM
Press Select for 12 or 24 clock hour
Press STORE (Auto Dial button)
Press END (Hold button) to exit
Jan 08, 2008 | Panasonic KX-T7431 Corded Phone
Nec dterm80
Another solution is to pick up on intercom and dial 4 then 2 and hang up. That is the default DND cancel code. It can be used form single line phones within the system as well.
Oct 03, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Cisco 7912G IP Phone Logo
1,437 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
