Question about Samsung Televison & Video
What does Bit error level mean regarding LCD TV Series 4 mean when Signal Strength is low? Can customer fix this? If so, How?
  • 192 Answers
SOURCE: low to no signal strength
Try agusting the wirless properties for your wirless card. You will need to go uder start then go to conect to and the show all conecsions. The you will need to right clcik on the wirless conecsion and go to properties. Now you will click the button that says configure. I hope this helps
Posted on Jan 03, 2009
  • 1214 Answers
SOURCE: NO DTV CHANNELS
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
Posted on Feb 16, 2009
  • 106 Answers
SOURCE: 1994 Lincoln Continental Executive Series oil level indicator
There is a known issue with the connector for the instrument cluster
Posted on Aug 03, 2009
barbu51
  • 566 Answers
SOURCE: Under signal information I've got bit error level
Hi zaikovskis
I`m going to help you with your tv but first; could i have the brand name and model number?
Should be written on the back of the set.
Posted on Mar 31, 2010
  • 1428 Answers
SOURCE: low wireless signal strength compared to other computers
For HP Mini 1000, the wireless device can be problematic.
I will recommend the HP Mini 210-1084. This has the fastest wireless in the HP Mini range of Netbooks.
Good luck.
Posted on Jul 17, 2010
Lg tv says no signal
1) check the cabling with a tester to ensure both ends works at connected.
2) check the tv signal out from the wall mount outlet with a tester to ensure tv signalling is at acceptable level of strength;
3) if both works, then direct connect the TV to the wallmount tv signal outlet. If still not working, then ask the technicans to come in for fixing.
Jul 24, 2014 | LG 42LG50 42 in. LCD HDTV
The bit error level is 10 on the Ch7 stations but ok on all other stations and the signal strength is around 50 Any idea how to fix. Plugged in a different smaller TV into the same coax cable connection...
Plugging in a different tv does not really prove much, tuners vary slightly in the way they handle signals It may just be that your aerial needs a very slight adjustment or has degraded slightly.
Can you plug the coax into another device (vcr?) and out of that into the tv and see what happens?
vote appreciated
Feb 03, 2011 | Samsung Televison & Video
Low wireless signal wbr 2310 on signal strength
Hi Thanks for your question.
My advice would be to consider moving your router to different place. Put it a bit higher. There's also a lot of products like bigger antennas and wireless range expanders that you could consider buying. Here's link to some of the products so you can have a look what I mean---> click hear You could also try low cost home ways to boost your signal like- Attach a bit of aluminum foil to the router antenna. Position the foil so that the signal bounces off the foil in the direction of your computer. I hope this was helpful. Good Luck
May 08, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Dish vip 622 and vip 722k frequent picture freeze and restart
Sounds like a signal strength issue. You may have either a low signal or something like a tree limb is blowing into the signal path dropping the signal strength to a point low enough to causes issues.
Apr 13, 2010 | Televison & Video
Under signal information I've got bit error level 10 and signal strength 0. TV just stopped showing channels. What do I do? Already tried retuning, didn't find any channel.
Hi zaikovskis
Mar 31, 2010 | Samsung Televison & Video
Most of the channels breaking up despite auto retuning
could be one of a few things,
low signal strength, aerial out of line with transmitter.
bad coax connections losing signal strength.
coax broken inside, or old and not low loss.
Get the aerial checked for direction, half a degree out of line over a few miles and you will lose a lot of signal strength, as will old coax (aerial cable) and if you are using an unshielded coax you could be losing signal strength through the cable itself. Replace the connecters and try to use a straight run of cable instead of having joins in it as these joins, even if using connecters, will cause a weak signal. If yiu are running more than one tv off your aerial, invest in a booster.
Feb 06, 2010 | LG 32LG30 32 in. LCD HDTV
Trying to retune Samsung LCD TV LE26R7 but settings (4th option on menu) is greyed out and won't let me access to retune was okay before sept 30th
HI,this might just help!...
1.press D.MENU on youre tv remote
2.scroll down to SYSTEM
3.access the RESET function
4 enter 0000
5 follow on screen instructions
TV will then wipe all existing channels and start from scratch.
worked a treat on my SAMSUNG LE26R7........However i noticed my signal strength dropped significantly!!...obviously them at the other end (digital tv boffins)have been mucking about,A bit of fiddling about with my existing arial did the trick!!
REGARDS.......G WATSON
Oct 02, 2009 | Samsung Televison & Video
NO DTV CHANNELS
Feb 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LCD LNT4042H
Hi Barb,
Unfortunatly the problem you are asking about is a normal happening in our area with customers of mine that use rabbit ear or house mounted antennas ( Normally not cable or satellite dish). This problem sounds to me like a lack of signal strength on certain channels where your loosing your sound. Since your LCD TV is digital it requires a bit more signal strength to produce sound and picture. Maybe a better antenna, or redirection the antenna toward the station transmitter. Hope this helps.
Ed
NC Electronic
Mills, Wyoming
Jan 05, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
524 people viewed this question
Henry  Thomas
Henry Thomas
