Question about LG WM0642H
LG Wm0642H door seal problem
I have a new LG that has a rip in the door seal. How can I replace this?
    Sniper:
  • 68 Answers
I replaced the seal on my mother-in-laws LG washer last month. The seal has 2 bands. One that the attaches to the drum, and one that attaches to the front of the washer. The hardest part about replacing the seal, is gaining access to the seal. Once you gain access to the seal, it can be a little tricky getting the bands back on, because you have limited area to work. There is no special tool or tricks to get it back on, just persistance.
Posted on Jul 28, 2008
Leaking water from front of door. Replaced boot seal but still leaking. It looks like door is kicked out at the bottom. Would replacing the hinges help?
Try turning the water pressure down. If you have high water pressure the water comes into the dispenser to hard and splashes over the front & side of the dispenser draw the trickles down the inside of the front panel out on to the floor. Very common front loader problem.
Aug 06, 2015 | LG WM0642H Front Load
Water leak out the bottom of the door when it running door seam lose
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Manufacturer Part Number 4986ER0004G
Jan 27, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Drum on LG washer is tilting backwards, and ripped door seal
What your problem is that you say that the springs are fine what you have forgot to look at is the other part , same as a car you have springs and shocks that is what it not working anymore you need new ones shocks that is. Or you will have to buy a new washer okay.
Dec 02, 2013 | LG WM1814CW Front Load Washer
My washer is giving theOE signal indicating a clog. I drained the bottom tube and cleaned the filter. Still makes a grinding sound when it tries to drain. Drained from the bottom twice more but...
You have a broken drain pump and needs to be replaced. The part number is 4681EA2001D. This is a big job requiring a special tool to remove the spring clamp on the door seal.
Good luck.
Jul 11, 2011 | LG WM0642H Front Load
What can i used to seal the rubber in the washing machine
Nothing, if the door seal is damaged, it has to be replaced.
Jul 09, 2011 | LG WM0642H
How to replace lg rubber gasket forn a front loading washing machine model wm0642
You will need 2 special tools to remove and install the door gaskets. The springs are very hard to put back together with anything other than the proper LG tools.
Good luck
Jun 04, 2011 | LG WM0642H Front Load
The rubber seal on my LG WM2016CW has a rip on it and needs to be replaced. The door still seals but water runs out of it. Is there a name for this part or is it just called a rubber seal? How do I...
If the door is sealed water wont run out of the seal? A small rip does not mean it is failed...I am a bit confused but I can tell you that there are also seals in the pump and moter and discharge areas in the BOTTOM of the machine that can fail ... I would need more information to help you further...a reply would be appreciated
Feb 14, 2011 | Washing Machines
I can't find a tub clean feature on my LG WM0642HW. I am having trouble with moldy smelling clothing and want to try some of your solutions but can't find the tub clean feature.
My LG doesn't have one either, but I recall that they recommend using the "Rinse and Spin" feature. Add a bit of chlorine bleach, run the cycle, and then "always" leave the door ajar after each use so that the machine can dry out. Cleaning out the drain area at the bottom of the rubber door seal helps too. You'd be surprised what I've found there -- other than the usual dog and cat hair!
Aug 10, 2010 | LG WM0642H Front Load
LG WM0642H Logo
272 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
