Question about Onkyo Audio Players & Recorders
Hello- I recently purchased an Onkyo TX 2000 (170 watt/60hz/120 volt) from a garage sale (I should've tested it there but didn't). I plugged it in at home and got no power lights at all. Checked all fuses internally but all are ok. Any suggestions? Thanks a lot!!
  • 979 Answers
This will require a service manual and checking of the transformer and power supply system...accordianman
Posted on Jul 28, 2008
Hi, I recently purchased a used makita 6100r generator and when checking it out I discovered on my 30 amp 220 receptacles arent getting full power. I took out the receptacle and checked the wires in back...
You may be asking too much of the unit; the 5800 watts a which it is spec'd, may be a 'peak' power rating which may be 15-20% higher than its continuous rating. 30 Amps at 220 volts implies 6600 watts which is higher than even the peak power rating. I would expect the unit to produce ~4800 watts continuous or around 22 Amps.
Decided to check my statements and found this, which I quote:
Generator Volts AC (60Hz) 120/240 Max. Output Current 5800W-48.3A/24.2A Rated Output Current 4800W-40A/20A Volts DC (AMPS) 12 (8.3)
Aug 28, 2011 | Makita G6100R 5800 Watt Generator
My Onkyo TX-SR806 remote has recently lost its mind. The On/Standby switch no longer turns receiver on or off; must do it manually on the receiver. The Volume control is now reversed: when you press the UP...
Hello, the most used buttons can wear out over time. On/standby and volume are the ones that are used most often. I suggest purchasing a new remote. It is available at shoponkyo.com. Thank you, Onkyo USA
Jul 08, 2017 | Onkyo TX-SR806 Receiver
Need to convert 120V AC/DC current to 120V AC 60Hz 15W
there is no such thing as "ac/dc" current-its either one or the other--if its a 120 Volts then chances are it is AC already-at 60hz---the 15 Watts or any Watts is the amount of draw from the unit-not the power supplied to it- Watts= Volts(supplied)/Amps(being used) if you only want to supply 15 watts then reduce the amps (with a fuse) to .125amps
Mar 26, 2010 | Computers & Internet
Remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Mar 06, 2009 | Onkyo TX-SR606 Receiver
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Onkyo TX 304E - mp3 audio format
Hello, please try different listening modes. Thank you. Onkyo USA
Mar 30, 2017 | Onkyo Audio Players & Recorders
Power conversion
If you have 110 - 120 volts AC at 60Hz, then the mixer must be bad. Unless 50 Watts isn't enough. Does the voltage drop when you plug in the Mixer to the convertor?
Geno
Mar 05, 2008 | Denon Dn-X1500 Professional DJ Mixer...
Onkyo TX-SR804 power supply
If you imply an AC voltage transformer by saying "power supply", I don't believe it will be difficult to find one. If you stay in Istanbul, I recommend that you go to "Dogubank". You can choose from a wide variety of options at that place. All you have to pay attention is that the AC frequency (Hz) of the transformer you're about to purchase. It must be around 50Hz to operate your amp.
May 05, 2007 | Onkyo TX-SR803 Receiver
83 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
