My dj amplifier gets hot and just shuts off i have to cut off and cut back on again
  • 1 more comment
  • king-patrick Jul 28, 2008
    my question was my amp keeps cutting off during gigs i didnt understand when he said i have sreaker overload "why is my amp getting so hot i also have a fan
    i gess it gets hot because i had too many speakers hook to the amp
  • king-patrick Jul 29, 2008
    the dj amplifier specs are 1400 watts rms @4hm 700 watts per channel at 4olms 350 watts per channel at 8 olms the wattage of the speakers are 900 watts
    Novelist:
    Scholar:
  • 96 Answers
I believe he is attempting to tell you that he thinks your Amp is overloaded and that you might have too much hooked up to it. Reducing either the number of speakers you have hooked up to it, or using speakers that demand less power would solve the problem.
That assumes that you are doing something different than you have been doing up to the point the amp began to overheat.
If this is recent and you have not changed anything, check your fans and make sure that all internal fans are still operating.
Sometimes, the fans may be spinning, but not enough to move any air. Check the fans for scratches or peeling edges, which might indicate that the fan housings have taken some damage while the apm is moved from place to place. This could slow the fan down and recude it's effectiveness. Also check for lint buildup or anything else that may have blocked the airways inside the amp if you can open the case and take a look inside.
Posted on Jul 28, 2008
  • 790 Answers
Hi
if the amplifier is too hot you have overloading by more speaker
Thanks!
  • 2 more comments
  • carlos fernandez Jr.
    carlos fernandez Jr. Jul 28, 2008
    do not overload your amplifier! thats why you got hot amplifier.
    ok
    1. overloading
    2. you have defective Relay
    3 you have shorted speaker
    Thanks!
    yes that is overload
    can you give to me the specs of the amplifier and the speaker! i can give you a tips how to setup!
#ks-ax3205d. Why does it shut down, then turn on again?
Your amplifier is shutting down because of an overload or incorrect output load.
Jul 27, 2015 | JVC Car Audio & Video
640 amplifier manual
What you have is a semiconductor (transistor or IC) that is getting hot and so shuts down. You can trace it by running the amp and with the top cover off, blasting any suspects parts (one at a time) with Servisol Freezer Spray. You will have to wait will it goes dead, before spraying. If it comes back to life after spraying you have found the faulty part.
Sep 20, 2013 | Audio Players & Recorders
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
Amp kicks off after a few minutes of play. It will play again after a few minutes, but then kicks off again.
My best guess is that your over loading the amp. Check and see if the amp is hot when it cuts off. Most amps have a "safety" cutoff that will shut it off if it get to hot
Oct 26, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Car shuts off when it gets hot
your ignition coil are going bad, they need to be replaced. once the car gets hot the circuit shut down the car when hot. once they cool your riding again until they get hot. thats your problem. Good Luck
Jul 31, 2010 | 1988 Buick Electra
My jl 500.1 amp dosent play anything.
you have your sub wired incorrectly. your amp shouldn't get hot unless you're settings are too high or your'e sending too small of an ohm load to the amp. this would cause it to heat up and will fry your amp.
May 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
Amplifier turns off for no reason...while driving. If I restart the car it works again. Turn on lead is still hot (12V) when I test it and yet the amplifier just cuts out for no reason.
if your amp keeps shutting off, it means that you r overworking it, and it's getting hot without minimal time to cool off. my solution is, and i've done this. i bought four mini fans and wired them to the heat vents, two of them to the vents on one side to **** in cool air, and the other two on the opposite to **** out the hot air. this does work, and keeps your amp cool, or buy an amp that comes equipped with a built in fan, you may pay alittle more, as they say you get what you pay for. hopes this works for you
Feb 10, 2010 | Alpine Car Audio & Video
My koiler car amp shuts off and gets hot. when i shut off the car stereo and turn it on, it kicks back on and works till it gets out again.
Sounds like an overload...check the impedence of your speaker system and make sure that your amp is rated as stable at that impedence
Apr 12, 2009 | Koiiler XM-7676W Car Audio Amplifier
Denon AVR-4802R automatically shuts off in multi-zone mode
i had the volume of the multi-zone tuned too high and was attenuating it in an external control box. Once i took the multi-zone volume down to -25db, the problem went way. My main zone was operating around -35db so did not have the problem.
Nov 23, 2008 | Denon AVR-4802 Receiver
Car amp
I believe the answer is both. The amp gets too hot and cuts off the circuitry and causes the amp to go into protection.
Your amp is only designed to run at 2 and 4 ohms. What you need to do is check out this site and run your subs at a 2 ohm load.
If your subs are dual voice. Run + to + to +, - to - to - in box. Run + and -, + and - to amplifier in stereo. Your amp won't shut off anymore.
Nov 08, 2006 | American Pro VS1405 Car Audio Amplifier
59 people viewed this question
 Grubhead
Grubhead
