Question about Nintendo DS Lite Console
Help me ok well my problem is i tried to update my ar and when i saw it was deleting everything i turned it off. now when i try to put stuff on it it says failed not enough free space. but theres NOTHING on my ar because it deleted it all HELP!!!!
If u turn it off you might not of deleted the data
Posted on Jul 31, 2008
Hello I have a problem with my ps3 whenever i turn on my ps3 it says 99% ps3 software update but never 100% can you please help thank-you.
ok when trying to turn on your ps3 dont let go off the on/off button wait till you hear an extra beep and that will reset some stuff and it should let you get that update dont worry it doesnt delete anything just resets software and also it takes the picture of the screen but its still on your ps3 so just put it back on and thats everything enjoy
Jan 12, 2011 | Sony Playstation 3 (PS3) Console
The 4gb Micro SD card is not working. First I formatted it with my phone then I put it in my computer and a picture on it and safely removed it from my computer and put it back into my phone. It showed the...
ok the first thing to do is find out is , is it the phone or the memory card, so try another memory card. with a bit of luck it will be the card that is unstable. if its not the try updating the the firmware on your phone but do it using the pc suite that maches your phone and backup your entire phone contacts pics etc to your computer. now dowload and install the update usually the pc suite will do this for you. i hope that helps.
Jan 12, 2011 | PNY 4GB microSD High Capacity Mobile Media...
F4-02 Improper Cartridge message on Sharp AR-M450N multi-function Tried everything -- unplugging everything -- turning everything back on then tried #*C* 14 enter 1 enter also tried 15 enter 1...
You may just have a Bad Toner Cartridge... It will happen from time to time..... There is a IC chip on the back of the cartridge, it may be bad or the toner feed screw is bound up... Replace the cartride with a new one..... Also, is it a OEM toner cartridge or a genaric one?
May 04, 2010 | Sharp AR-M450N Copier
My action replay doesn't work with the game Animal crossing Wild
There are two possible reasons why it won't work 1. You used may have used to many cheats at once which overloaded the Action Replay. 2. I have noticed that sometimes there are a few bad codes that cause the game to mess up and freeze when the Action Replay is used.
Happy Fixing :u)
Oct 19, 2009 | Datel Action Replay for Nintendo DS
2 blank screens after update
The Action Replay has been wiped of all data and all you can do is buy a new one. The same thing happen to mine after I tried to update it, and I called datel and they said that you turned your DS off while it was trying to save and it corrupted the data on the AR. And since the data is corrupted, it wont start.
Mar 29, 2009 | Datel Action Replay for Nintendo DS
Action replay problem
Your AR Cartridge probably needs a cleaning. Use some rubbing alcohol and a q-tip and rub it on the pins of the AR Cartridge. Then use a dry q-tip to dry the rubbing alchohol. If that doesn't work then you should probably buy a new AR.
Mar 01, 2009 | Nintendo DS Lite Console
Add game file problem
ok that means its bricked.
hold a and b while its off with the ar in it, and when you see a BLANK white screen hold down start and select, too. if "this product is not liscensed or endorsed by nintendo" stays for about 7 seconds, you de-bricked it. now try putting the codes on (the code manager will work now, too)
Feb 18, 2009 | Nintendo DS Lite Console
Install sound card and I lose the CD/DVD drive.
You may need updated drivers. Try downloading the latest drivers for your soundcard. If you are using Windows Vista make sure you download the vista drivers as most Windows XP drivers will not work with Vista. Hope this helps.
Dec 23, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Sorry, my last desc should be ignored here are all to solutions to problems. I know:
Prob: Two white Screens:
Solution: none so far, have emails sent to Datel. see what happens. This occurs when attempting save codes with the DS and the AR is pulled out or DS powered off. My suggestion if you get a new one, only update codes using the PC software.
Prob: AR keeps asking for game cart. insertion:
Solution: remove AR and put in game cart.
Prob: AR not enough memory to update codes:
Solution: there is more bugs in their software/firmware that doesn't really know when items are deleted and space is free. You must reset AR cart. and then use the PC software to reload all the codes:
a) First I would update the AR PC software (no DS AR connected)
b) Connect DS with AR to PC then update the AR firmware
c) Disconnect DS AR from PC
d) DS off hold A+B when TURN ON DS when DS logo shows press START+SELECT with A+B still down as well, hold for a while. turn off DS
e) Reconnect to PC, turn on DS and drag the PC US codes to the DS side. (Note: I had to do 4 & 5 a couple of times it finally worked)
Prob: AR PC software not seeing the DS AR connection: Solution: The PC drivers are not being found for the NDS link. You need to do the following:
a) close the AR PC software, and disconnect the AR DS.
b) connect the AR DS and then the windows new hardware driver install window pops up. must select using the manual browse option.
c) go the the action replay directory either on the action replay CD you bought or from a extracted version from the web. (NOTE: this is not the installed location, but before where the setup.exe exists) I had lost my CD and did about 10 minutes and found a .rar of the source code.
d) pick the action replay subdirectory and click on install
e) you should see the NDS link drivers being installed.
f) start the AR PC software and attempt to connect the DS AR it should work.
-- I hope this helps anyone --
Nov 23, 2007 | Nintendo DS Lite Console
Mi dvd-burner doesnt recognize blank DVDs and doesnt burn them
try downloading www.slysoft.com thier Dvd player play and burns everything and you can do a trail run for 20 days or so lala linda
Oct 03, 2007 | NEC ND-3540A DVD RW Dual Layer Burner
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
