Question about Microsoft Xbox 360 Console
Three red sections
Where my power ring is there are 3 red rings instead of 4 green one...... what do i do???
  • Anonymous Jul 30, 2008
    There are repair guides out there that will fix it - but you had better find the right one for the job - here's a website that will help with that:
    www.BestXBOX360RepairGuides.info
    Good Luck!
    Good Luck!
360-Pros.com =)
Posted on Jul 30, 2008
Good Luck!
Xbox is coming up with an error screen and has a red ring instead of a green one on the power button
2 red rings is over heated 3 is harware fail 4 is missing power and 1 is the hardest to fix for exact error code turn on hold controller connect and press eject 4 is for 0 1 is for 1 and so on remember the code and look it up it will tell you the problem most likely red rings of death so send it to microsoft call at 1-800-4my-xbox or look up a guide or buy one off ebay there cheap and easy
Dec 04, 2010 | Video Game Consoles & Games
My console plays my games, but there is a full red ring? what does this mean?
OUCH! You have the red ring of death! Did you by chance have xbox on it's side for a long period of time instead of flat? If so, that's why. They say there made to do this, just like the old ps2's, It a load of ****. The laser lens circuit will need to be replaced. If you didn't have it on it's side, then you have a bad graphics chip, or cold solder joints, or the motherboard is shot.
Step 1: Turn on the console, and check the light on your power supply loadTOCNode(2, 'moreinformation'); The power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair request loadTOCNode(3, 'moreinformation'); Your console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: uparrow.gifBack to the top Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this image3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it on loadTOCNode(3, 'moreinformation'); This will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supply loadTOCNode(3, 'moreinformation'); If the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply.
Jan 30, 2010 | Microsoft Xbox 360 Console
When i play xboxlive it will freez then the screen will be green or red then i have to turn my xbox help
If this is what happens each time you use your your console, it might be broken. Does it have any red rings around the console's display? If that's the case, check out these links by Microsoft corresponding to the amount of red rings on your console:
1 red ring
2 red rings
3 red rings
4 red rings
They extended the warranty to three years from the purchase date for the three rings. Give them a call at 1-800-4MYXBOX and see if they can't help solve your problem. Hopefully you're still under warranty. Good Luck!
Jan 08, 2010 | Microsoft Xbox 360 Console
Red ring on console
As you didn’t state how many red lights are on your Xbox i will post all the Red ring of death errors.
All sections red (4 Red Lights) = Could not detect the AV cable. Check all of the cables at the back of the console.
3 Red lights (Sections 1, 3, 4) = General hardware failure. Contact Microsoft Support.
2 Red lights (Sections 1, 3) = Overheating. Make sure that your console is in a well-ventilated area with a good air flow and try again.
1 red light (Section 4)= Hardware failure. This is usually combined with an error code on screen. Contact Xbox support.
Nov 17, 2009 | Microsoft Xbox 360 Console
X bow stalls
3 rings would be the ol' Red Ring of Death, while 4 rings means the AV cables are not detected.
Jun 19, 2009 | Microsoft Xbox 360 Console
IGOT 3 RINGS OF DETH
Three red lights on the ring of light is an indication of a hardware failure
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Apr 14, 2009 | Microsoft Xbox 360 Console
My xbox 360 has three red rings and one green in the middle
the 3 red rings are the worst and there is no way to fix it, i tried wrapping a towel around it and leaving it for an hour or so and that worked for me... the is a good old xbox remidee, but if that dosnt work then call the hot line and you will have to send it off.. the usually have it back in about a week
thanks, max
Dec 15, 2008 | Microsoft Xbox 360 Console
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
The green ring of light on my xbox360 keeps going to red
how many red rings do you get is it red ring of death with only 3 lit or what?
Jul 02, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
