Question about Toshiba Satellite P205-S6287 Notebook PC
AutoCad Where can I go to buy AutoCad for my computer? Preferably a store.
  • 813 Answers
U need to go professnol delar of autocad or u can download from the internet & crack the software u will free use it
Posted on Jul 28, 2008
What is the activation code of AutoCAD 2010 ?
To get the activation code you should BUY Autocad.
If you want a free product, look for FREE PROGECAT 2009
an Autocad alaike
AutoCAD Compatible Software FREE for non business use only
Aug 31, 2015 | Autodesk AutoCAD 2010
How to recover AutoCAD files from flesh card?
If you need to recover it as fast as it possible install Recovery Toolbox for DWG , this thing is able to help you. But it's not free. Download free demo here:
http://www.dwg.recoverytoolbox.com/
As one of solutions I can advise you to try to open your files in MS Visio, Compass or using another program which could open dwg file. Or try to recover them using AutoCAD recovery function.
Also you can read here about dwg file corruption:
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/561-how-to-recover-autocad-files-from-flesh-card
Nov 27, 2014 | AcroCAD Software AutoCAD DWG to PDF...
What stores in Jacksonville, Fl sell Autocad-2010?
The current version is AutoCad 2015.
Would suggest checking ebay. Didn't see any product right now, but there are some laptops for sale with Autocad 2010 installed. If you don't want to run off a laptop, you might be able to export the licence and then install Autocad 2010 on another computer.
Aug 16, 2014 | Autodesk AutoCAD 2010 Full Version for PC...
My AutoCAD LT 2008 serial number is oldest
Serial numbers for software products are unique to that product. There is no way to get a 'new' serial number for a product. If you are interested in purchasing and using a newer version of AutoCAD you may go here:
http://usa.autodesk.com/autocad/how-to-buy/
Dec 09, 2012 | Autodesk AutoCAD LT 2008
What is the product key for autocad 2010 if the serial number is 80010409?
Fixya doesn't promote piracy, nor it provides product key for AutoCad. You should buy AutoCad.
Feb 17, 2011 | Computers & Internet
I cannot install my autocad 2010 because it says that my processor is not sse2 compliant. is there a way to install it for free?
Hi
I'm sorry you can not use the program with your old computer, the requirements are.
  • Intel® Pentium® 4 or AMD Athlon® dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
If your processor does not have SSe2 technology support, it is too old to run the program, buy a new machine. Or use a older version of autocad. your computer must be around 5 or 10 years old or more. SSE2 has been around since 2003.
Quote http://autodesk.blogs.com/between_the_lines/2009/03/sse2-cpu-support-requirement-for-autocad-2010.html
23 March 2009
SSE2 CPU Support Requirement for AutoCAD 2010 I will try to not geek out and confuse you on this post. With AutoCAD 2010 there is an AutoCAD 2010 System Requirement to have a CPU (essentially the computer’s brain) with SSE2 support. SSE2 is an Intel CPU instruction set (SIMD Extension 2) which is essentially technology to replace the old MMX extensions which are half as slow in many data and math operations. Most current systems will support SSE2 except an old AMD CPU system over 6 years old. AMD Opteron, Athlon 64 both support SSE2 and have since 2003.
So why SSE2 requirement in AutoCAD 2010:
In developing software there is a limit on how old of technology you can effectively support without impacting current hardware and software users. In the case of AutoCAD 2010 adding the SSE2 requirement this increases performance for customers using current hardware. Many areas improve in AutoCAD such as OSNAPs.
I said I would not geek out so I will not go into details on floats, floating point, and registers. Your experience may vary but the change was made for some performance benefit of current hardware.
Bottom Line: Increasing performance is a good thing!
End Quote.
Dec 15, 2009 | Autodesk AutoCAD 2010
I need to run Autocad 2010 on my computer but it won't even instal because I have an AMD 3000+ 2Ghz processor. Is it possible to upgrade the processor without buying a whole new computer?
Autocad 2010 needs SSE2 to run.
The only Semprons which didn't have SSE2 are those for socket A, so I assume you're running a socket A mainboard. I checked and there are no socket A processors that support SSE2 unfortunately.
I think that you could replace your mainboard and the cpu cheaply witha a socket 754 mainboard (which supports SSE2 CPUs and should run with your old ram).
However I advise to upgrade to newer system with AM2 socket or so - they aren't expensive and the increase in performance in power-hungry applications such as AutoCad will be noticeable.
Oct 12, 2009 | AMD (SDA3000BOBOX) Sempron 3000+, 2 GHz...
I want to run autocad on genuine on vista home basic
its better u buy new software but if u r learner then best way is u use trial version and there is no problem of any type with vista, but remember piracy is not good thing, :-)
Aug 24, 2009 | Microsoft Windows Vista Home Basic Edition
AutoCad LT 2006 incompatible with Windows Vista
some of the older versions of autocad does'nt tend to work in vista.try installing autocad 2008 or 2009.it is recently released and well compatible with vista.REMEMBER, if u r using it for architectural purposes,try downloading autocad architecture 2008.it is especially made for architects.try downloading it on torrentz.com
Jun 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Toshiba Satellite P205-S6287 Notebook PC Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
