Question about HP Office Equipment & Supplies
The paper feed machinism doesn't work properly - so that when the paper is feed through it does it crookedly resulting in paper jams. this only occurs whilst faxing, it feeds ok when photocopying
    New Friend:
  • 159 Answers
What is the printer type?
Posted on Jul 28, 2008
The printer won't feed the paper in properly. It turns crooked and then doesn't load in. Printer thinks there is either no paper or a jam. Can see anything physically in the way blocking the...
Hi Trevo
First, check the the paper guide in the feed tray is up against the edge of the paper. If it is not snug then the paper will skew.
If it is OK then check with a torch both sides of the paper path - where it goes in and where it comes out.
I've found bits in the path before now that are not seen at first.
This printer may have a removeable panel at the back where you can check a bit more easily.
May 25, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Tip
My X2250 will not feed the single sheet of paper evenly. When looking at the...
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just needed a little more tension on the roller that pulled the paper in.
I removed the rear access door (see manual). Off to the left near the feeder roller you will see a spring. What I did is mover the spring to the END of the plastic arm that it is attached to (if it is missing ..you have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch ...and that is all all it took for me. My printer will now feed a single sheet of paper with no issues. BTW: I put a drop of glue on it after so it would not slip off.
on Sep 28, 2008 | HP PSC 1610 All-In-One InkJet Printer
My printer will not feed the paper properly. It
There must be a jam on the left side then. Open and look inside for the paper issue
Jun 16, 2010 | Lexmark JetPrinter Z11 InkJet Color...
The paper won't feed through. it did one minute then stopped
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). This, if properly done should do it. Brush especially the rollers etc.
Dec 06, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam! paper begins to feed then goes crooked
Please do all the things that you can do before you consider buying a new printer. You can take your printer into a service repair center or computer repair center in your place. If there is nothing that they can do then you can take an option of buying a new one.
Nov 28, 2009 | Lexmark X4530 InkJet Printer
Paper feeds crooked and results in a paper jam.
Assume every time this happens something microscopic fell into that tiny pinch of an area. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over and shake it around til the little bugger falls out.
Oct 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
MY HP Officejet Pro L7780 prints crooked and jams
Make sure the paper guides are tight against the paper. You can also try cleaning the feed rollers with water and dish liquid on a cloth. Check for any paper that is stuck inside. Remove any rear panels that give a straight-through path and check in there. The smallest piece of torn paper will cause this.
If all fails, buy a Canon MP series ;>)
Feb 15, 2018 | HP Officejet Pro L7780 All-In-One InkJet...
Paper Jam
there maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
cheers
Aug 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Dell 1700 Transfer Roller
These series printers have a typical problem of the paper pickup rollers wearing out resulting in jams, crooked feeds and partial feeds. a quick fix:
take the paper tray out, turn the printer on edge and locate those two rubber roller bands on the pickup arm. Peel them off, flip them inside-out and return them to the rollers. This restores thier sticky rubber side so the papper feeds properly.
Now if you are a heavy printer, you can order some of these from dell for the next time. Washing these in handsaop and water works sometimes too. never use alcohol.
Jan 06, 2008 | Dell 1700n Laser Printer
111 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
