See Below.
Hope this helps.
Zeppelinx12
Fuse Panel, Explorer
EXPLORER FUSE PANEL
Fuse Position
Rating
Circuit Protected
10 Amp
Power Mirrors/Antenna
10 Amp
Air Bag/Blower Relay
15 Amp
Parking Lamps
15 Amp
Left Headlamp
5
10 Amp
On Board Diagnostic II System
6
15 Amp
HO2S Sensors
7
10 Amp
Illumination Switches
8
15 Amp
Right Headlamp/Fog Lamp System
9
10 Amp
EATC Mem./Seat Mem./Mess. Ctr./Cell. Phone
10
10 Amp
EATC Sys./Rear Blower/Spd. Control/GEM Sys./Brake Interlock/OH Console Adapt. Susp.
11
10 Amp
Warning Lamps
12
10 Amp
Front and Rear Washers
13
15 Amp
PCM Sys./Stoplamps/4WD/
ABS/Spd. Control/Trailer Tow
14
10 Amp
Anti-Lock System
15
15 Amp
Air Bag System/Alternator
16
30 Amp
Front Wiper
17
30 Amp
Cigar Lighter
18
15 Amp
A/C System
19
25 Amp
Ignition Coil/PCM System
20
10 Amp
Radio/Power Ant./GEM Sys./Anti-Theft/Cell. Phone
21
15 Amp
Hazard Lamps
22
15 Amp
Turn Signals
23
15 Amp
Rear Wiper System
24
15 Amp
Starter Relay/Anti-Theft
25
10 Amp
Speedometer/GEM System
26
15 Amp
A4LDE Trans/DRL Sys./Backup Lamps/4WD/Rear Defroster
27
15 Amp
Under Hood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/Accessory Delay/DR Switch Illum./4x4 System
28
10 Amp
Memory Seat/GEM System
29
15 Amp
Audio System
30
Not Used
31
10 Amp
Aux. Blower System
32
10 Amp
Heated Mirrors/Heated Backlite
33
20 Amp
High Beam Lamps
34
10 Amp
Audio System/Power Antenna
35
Not Used
36
Not Used
SOURCE: I need a fuse box diagram for a 2003 Ford Explorer
I believe that this is what you are looking for.....
Fuse and relay locations--2nd generation power distribution box Layout-
I think this is a good sticky candidate--
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat, Message center
__________________
SOURCE: diagram for fuse box/1995 ford explorer not
I suggest check in this link the Ford-Explorer-owners-guide
Hope thss helps (remember to rate this answer).
SOURCE: fuse box diagram
Here you go. Start on page 181.
http://www.motorcraftservice.com/pubs/content/~WOXEXP/~MUS~LEN/42/99expog1e.pdf
SOURCE: need to see fuse box diagram for a 2004 ford explorer
For the '04 Ford Explorer, here you can find the Owners Manual, and check the page 186 and next for the Maxifuses, Minifuses and Fuses.
I really hope helped woth this (remember rated this help). Good luck.
