Question about Kitchen Appliances - Others
Defective rotating grill motor
I have a FGranklin Chef stand alone electric roasting grill; the motor has stopped. I have disconnected the motor from the circuit board and mesured continuity accross the leads; it measures open circuit. I presume the motor is finished. My question is, whwre can I find a replacement moitor AM-06 5/6RPM, CW/CCW, AC 110V-120V, 50/60Hz, 4W, made by ANN YIH PRECISE INDUSTRY CO. LTD
  • linc2000 Apr 20, 2009
    I need the same motor. Did you get the motor from China? How long did it take and what did it cost? Linc2000@msn.com
I have found the manufacturer of the motor in China and have ordered a replacement part.
Thanks,
Canadiano1
Posted on Jul 28, 2008
  • sangoku101 Aug 19, 2011
    Would it be possible, after all this time to tell us all the info? I'm looking for the same motor right now.
    sangoku101@hotmail.com.
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
How long would I need to cook a 151/2 lb crown roast fo pork on a Weber grill. It has 18 ribs
Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. Be sure to cook over the cool side of a two-zone fire and rotate every once in awhile to even out which side faces the fire side.
Dec 23, 2017 | Weber Grilling
Machine error e03 20
Main Motor rotation 1. Drive Mechanism is defective.
2. Main Motor connector is disconnected.
3. Main Motor is defective.
4. DRV PCB connector is disconnected.
5. DRV PCB is defective.
6. SPC PCB connector is disconnected.
7. SPC PCB is defective.
8. LVPS is defectiv
Mar 18, 2014 | Panasonic DP-8060 MFP...
I purchased a PRO Chef electric hot pot a few months ago. I am very happy with the product but unfortunately the pump no longer works. Do you have any idea where I can get a new top piece?
pro chef electric water pot is defective. I bought 2 & both had pumps that stopped working. A friend has the same problem. Best way to fix the problem is not to buy this piece of junk!
Aug 28, 2011 | Le Chef Electric Shabbos Hot Water...
F-1 shows and we cant get it to stop buzzing and can not set the cook time.
Welcome to Fixya.
The problem could be:
1. Watchdog on board or
2. Touch membrane defective
To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board .
Thank you for using Fixya!
Nov 20, 2010 | Magic Chef 9512 Electric Single Oven
No manual
Just guessed how long to cook roast and worked it out with friends.
Dec 05, 2009 | European Outdoor Chef 800 Watts Dimension...
I was given a george Foreman Lean Grill machine with a Contact Roasting Machine both in the one box as a gift about a year ago. when I opened it I noticed one of the machines had been used. someone, had...
when speaking to a friend about the missing user manual, she mentioned another friend who she thought had the same grill as I have. When further enquiries made,we found this person did have one and is sending me a copy of the manual. . I still have not solved the meat thermometer problem., but I am sure I will be able to buy something suitable , somewhere
Nov 17, 2009 | George Foreman GR30 Indoor Grill
The drum on my dryer stopped turning it was heating and it just stopped turning, I just want to get instuctions on how to take it apart.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Jun 15, 2008 | Magic Chef Dryers
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
Kitchen Appliances - Others Logo
1,068 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
