Question about Toshiba Satellite P205-S6287 Notebook PC
Wireless Modems Which wireless modem would you recommend? And, can you use a wireless modem without setting up a network?
  • ishharris Jul 28, 2008
    I don't really think I have to worry about anyone intruding in my network though.
    I live about 500 yards from my neighbors. lol
  • Toshiba Master
  • 2,794 Answers
If you have DSL service, Actiontec makes a wireless DSL modem thats easy to setup. It had a built in router in it.
You should setup wireless security for your network so that you won't have any unauthorized inturders entering your network.
Posted on Jul 28, 2008
Why do I have trouble maintaining wireless network connection.
We recommend you contact ARRIS for Consumers for support with your Motorola Modem.
Motorola Support
May 31, 2014 | Motorola Computers & Internet
How to conect to wifi
You need to obtain and connect a wireless router to the modem to add a wireless network. Use an RJ-45 between the WAN port on the router and to the yellow port on the TM822G (or similar Arris telephony modem). Check with your ISP. If you have set your computer to obtain an IP address and DNS server automatically, you will have the router's wired connection set up immediately.
You will need to check the router's manual to find its IP address and administrative user name and password. Using a computer with a wired ethernet connection to the router, log in and set up the wireless network; you probably will want to change the network's default name to one that is easier to remember. Enable the encryption and use a password on your wireless network. (I recommend disabling the guest account option.)
Then go to your devices that can connect to the wireless network and set them up to find that network. (For some tablets, see the Settings > Network > Wireless menus. On Windows 7 and 8 computers, enable the wireless adapter if needed. Then go to the Control Panel > Network and Internet > Network and Sharing Center. Then set up a new connection.) Some routers have a WPS button on the back or front. If you press this button when prompted by the device, the router will send out a signal that will pair the device and the router without much effort. For other devices, you will need set the device to search for available networks and then type in the password.
I hope this helps.
(I have a Linksys wireless router but there are other manufacturers with well-reviewed routers.)
Jan 13, 2014 | Arris Tm802g Touchstone Docsis 3.0...
How do I configure for wireless?
Siemens Speedstream 4100 is just a modem, if you want to connect to the internet wireless you will need to set up your speedstream modem with a wireless router.
It can work with almost all the wireless routers available in the market, but I would recommend a Linksys wireless router.
Dec 31, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Do you have intalled wireles network adaptor driver?
Do you have enable wireles function on new laptop?
On the taskbar do you see the wireless icon?
Feb 24, 2010 | Computers & Internet
I have two desk top pcs, and two cable modems. how can i connect the other pc using one of the modems without paying for another cable bill?
get a wireless router and usb dongle for the second computer. Establish a home network and connect the wireless desktop to the existing cable modem via the wireless router.
Sep 27, 2009 | Computers & Internet
Can not make wireless work on an ACER Aspire 2930Z
Not shure how to help with the modems power issue without knowing the modems name but make shure the power cord is secure may aso try "start" "Control Panel" "Network connections" right click on "Wireless Network Connections" click on "properties" then click on "Internet Protocol" then "properties" make shur the "Obtain an IP address automatically" has the dot. if it does then try to go to the modems IP address this should be on the bottom or the back of the modem and config you wirelees setup from there, GL hope this helps.
Jun 20, 2009 | Acer Aspire 2930-4661 Notebook
My computer was wireless until I changed modems becausethe old one stoppd working
If you are using Windows XP, you go to start --> control panel --> network connections --> right click on wireless network connections & go to properties --> go to wireless network tab --> delete / remove all the networks under preferred network box then click on view available wireless or configure then connect to your network by clicking on the name of your modem --> type in the wireless password.
May 01, 2009 | 2wire (1000-000057-000) Modem
hard wire first the device to your modem and then configure the wireless settings to maximum channel. check if wireless settings is configured to the device you want to have wireless network with.
Feb 11, 2009 | Computers & Internet
2wire modem is not brodcasting wireless
Usually 2WIRE modems are automatically configured to broadcast wireless. If your modem is not broadcasting it can be due to a few minor D.I.Y issue.
1. Access your gateway address E.g in most cases
, access wireless settings, scroll down to see if the ENABLE SSID is checked. If it is not checked, check it and submit settings. Try searching for wireless again and it should appear in your wireless networks
2. Check your wireless channel if its in the default channel. By default it should be in channel 6. Too high channel will not broadbast wireless networks. E.G Channel 13 will not broadcast wireless. Even it does the wireless will not be strong enough.
Hope this may help and solve your problem
Jan 14, 2009 | 2wire (1000-000057-000) Modem
Toshiba Satellite P205-S6287 Notebook PC Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
