Question about Frigidaire GLRS264ZA Side by Side Refrigerator
FRIGIDAIRE SIDE BY SIDE
MY SIDE BY SIDE FRIDGE IS NOT COOLING THE FREEZER WAS WORKING FINE AND NOW SOME THINGS FEEL FROZEN AND SOME ARE NOT ALL THE WAY . THE TEMP IS AROUND 55 . WHAT CAN I DO ?
  • 943 Answers
Hi thanks for the question. your fridge isn't going in defrost cycle. locate the defrost timer, advance the timer to the defrost cycle . check to see if the defrost heaters are coming on. if not remove the back freezer panel. defrost with a hair blower, find a small disc on the coils .with 2 wires replace this part . its a defrost thermostat it stops the defrost cycle from coming on. thanks the appliance doc. please rate my answer.
Posted on Oct 08, 2008
I have a GE mdl PSI23SGRCSV side by side. initially the digital temp displays for both freezer and fridge sides went to 16 on freezer side and 43 on fridge side. This happened almost overnight it seemed....
it may be that your fridge is now low on freon the techs now do not know what to do the best thing to do is to call the tech and ask them to test the compressor pressures and see if it is low on charge. unless you know how to take the lower back panel off (the one that is probably cardboard) and feel the lines on the compressor and see if it is really cold and really hot that means that it is cooling properly but if it feels a little warm cominv out of the cooling side and hot on the return side then you need more freon.
Mar 04, 2011 | Refrigerators
Refrigerator not keeping things cool and freezer
this is usually caused by dirt either around the fan if its a built in fridge, or around the cooling fins at the back of the fridge.Make shure you unplug the fridge before investigating what is wrong.
Apr 13, 2010 | Hotpoint HSS25GFP Side by Side...
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
My freezer is working fine but by refrigerator is not working. how can that be with a maytag side by side?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 21, 2009 | Refrigerators
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My refrigerator is not getting cold
You should try to clean the coils under the fridge . Thats a simple thing to try .If your fridge /freezer cant remove the heat it wont cool ,also please make sure your doors are closing tight. We can start on all the free things you can try first..
Jul 11, 2008 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
RS21 DCNS FRIDGE COOLING FAULT
There is a fan behind the plastic. This distributes the cold air throughout the fridge. What happens is this fan stops turning due to freezing up. A temp solution is to unplug the samsung for 6-12 hours to allow the ice to melt from around the fan. This is a known design fault. It is easy to dismantle the plastic cover and defrost the frozen fan with a hair dryer, this way the fridge will only be off for about an hour
Aug 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
158 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
