Question about Durabrand 5.1 Surround Sound Computer Speakers
Short Circut, blows fuses instantly.
Im pretty sure this is the system that I have. Bought it in 2005, worked for a few years, one day, went to turn it on, and there was no power, replaced the fuse, and the second I turned the main switch in the back on, I heard it pop the new fuse. Any ideas
The thermal break that is part of the input transformer has developed a short circuit, replace the thermal break.
Posted on Sep 16, 2008
  • 12,061 Answers
OK usually the fuse goes because the Amp's IC's are drawing too much current thus the fuse blows... either this OR the Power Supply has gone Kaput. It is possible to replace the output IC's.. as it is to fix the PSU.. But it really is a shop job..
Posted on Jul 29, 2008
Why does my stop/horn fuse keep on blowing out?
you have a short circuit along the wiring... good luck trying to trace where that wire with worn out sheathing ~ usually at pinch points
Mar 21, 2015 | 1992 Honda Accord
Head lights go out even after replacing the bulbs
You have a short in the wires somewhere. Year , make , and model?
The short is between the fuse and the lights.
Dec 31, 2014 | Cars & Trucks
Hey i have a scosche in-line fuse block i purchased. I haven't had any problems until recently. My fuse fried. So i bought more and went to replace it and every fuse i try instantly fries. i cant seem
Most likely the amplifier you have hooked up to that fuse position is defective and causing the fuse to blow. Or you have a short in the powerline somewhere. Disconnect the power wire from the amplifier, tape up the end so it won't short out to anything. Replace the fuse, if it doesn't blow then you will need to get the amp checked, if it does blow, then you have a short somewhere along your power wire.
Jan 30, 2014 | Scosche Industries Car Audio & Video
Power Windows and Turn Signals Not Working - 15A Fuse keeps blowing
If a fuse keeps on blowing there is a short in the wireing to that circut, Your best bet is to take it into a auto electric shop to be check out,
Nov 28, 2012 | 2005 Subaru Impreza 2.5
Blown main ac fuse
a FEW ways this happens.
If fuse blows instantly when set plugged into power either a generic fuse (lots of these fuses are special and a generic will pop for no reason) or a dead short on the primary side of the power supply.
If fuse blows instantly when turned on a short either in secondary side of power supply or something it feeds.
First to try is get the exact fuse used (buy a pair) and see what happens.
beyond that if secondary side (when set is turned on) have an expert look at the set.
Apr 29, 2012 | Televison & Video
Power seat stops working the same day the dealership replaces the fuse for the 4th time. 2005 kia amanti
If the power seat keeps burning out fuses, then the motor in it is drawing too much amperage. There can be something caught in the tracks to the system that is causing enough physical resistance to the motion of the seat of cause this to happen.
It does not sound like a short circuit because it would blow instantly.
I would get a strong flashlight and a mirror and a hand full of fuses and try to recreate the failure while looking at the mechanism. There may be a cardboard carton jammed up inside the mechanism or a ball point pen refill in the track lodged in such a way as to repeatedly blow the fuses.
Hope this helps,
Best Regards,
Mark
Jan 05, 2011 | 2005 Kia Amanti
2000 Infiniti I30 blows fuses
NO ITS JUST A POWER SERGE THE WILL HAPPEN TO AVOID THAT TAKE THE BATTERY GROUND OFF NEXT TIME BEFORE REPLACING THE FUSE ;IF THE FUSE BLOW AFTER THE GROND IS BACK ON CHECK THE RADIO POWER SOURCE THERE COULD BE A SHORT SOME WHERE
Sep 15, 2009 | 2004 Infiniti I35
Blown fuses
there is a possibility that the current load is excessive nor there is a short circuit from elsewhere, do not try to install again a new fuse unless you are certain there is no shortages of any wire from inside the amp and throughout the system by physical inspection
also install the right value for your fuse meaning the right amp and voltage, high temp is an indicator of shortages and defective power transistor
Oct 06, 2008 | Pioneer GM-X862 Car Audio Amplifier
Durabrand 5.1 Surround Sound Computer Speakers Logo
133 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
