Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
No recording? Im using my samson mic with garageband. 5 seconds before it worked perfectly. then it just started making static sounds everytime i recorded. then later when the mic is plugged in and all. the mic that shows which im using is that one. when i click the record button and i speak or say anything to the mic, nothing records!
  • ihearthot Nov 19, 2008
    same exact problem! help!
  • 4 Answers
In garageband when you have the gtrack set up , it will show you 2 options for input source 'USB Audio CODEC'. This is because you have 2 lines in, the mic and the jack. Make sure you have picked the correct one to record the vocals...otherwise it is expecting the jack input and will record nothing.
Hope this helps!
gypsykingthing (AKA alisondking coz there's not enough space for my trad tag!)
Posted on May 14, 2009
The problem is, if you read the samson g-track manual, it says it is recording at 48kHz. now garageband supports only 44.1kHz, so this is an incompatibility issue. I reckon samson shouldn't have said the mic works with garageband because it simply doesn't. Using Logic Pro, you can edit your music project to be recording at 48kHz. I did, and my mic worked perfectly. So i guess the solution is to use a recording software that records at 48kHz.
Posted on Apr 24, 2009
I had the same problem before and it turned out to be the poor quality of the usb cable given with the mic so i bought a good quality usb cable and it worked perfectly. Also double check your settings in both garage band and system preferences. Maybe you just blew the mic...
Posted on Mar 25, 2009
    Problem Solver:
  • 27 Answers
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Posted on Mar 01, 2009
Mic sound muffled static
Buy a better mic! This question reminds me of the musicians who invest in a nice JBL public address system but then use Radio Shack microphones. A good quality mic, not GREAT but just good will cost you a minimum of $100. Quit playing with toys and invest in real recording gear. Computers and hard drive recorders can easily record CD quality audio, and-so why would you use a $70 mic?
Sep 10, 2013 | Samson Samtr Meteor Mic Usb Studio...
Whistling background noise with Samson C01U USB condenser mic
Welcome to the world of STUDIO microphones. Super quality BUT you must have a studio to use them. You can't have any local speaker playing into them. You often use headphones lest your monitor speakers will feedback. At the high frequency capability of these mics, you can fry your amps with oscillations above what you can hear!
Sep 28, 2009 | Samson C01U - USB Studio Condenser...
Samson G-Track mic does not work with garageband effects
Look man just use the input as a way for your pre-amp's to plug in.... you don't want any of those built in guitar effects anyways... You just need a good multi pedal.. There are many good recording Pre-amps out there that work great and are fully adjustable for easy recording.. You can do what you want but, I think you will like the sound of pre-amp effects pedals in your computer set up....
Thats just a tip
Sep 04, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
My microphone sounds muffled
Check wind screen. Make sure output level is not higher than volume level.
Dec 09, 2008 | Samson C03U Professional Microphone
Imac-samson-gtrack mic compatability
From the Samson Audio website...
"Ideal for the traveling musician or the project studio, the G-Track ships with a desktop mic stand, swivel stand mount, USB cable and all the cables needed to connect any musical instrument with a standard 1/4" or RCA output. The G-Track ships with Cakewalk's Sonar LE and works brilliantly with Apple's GarageBand."
If it states that it works with GarageBand, I would say that it would work on a mac.
Nov 29, 2008 | Apple iMac 24" Desktop
Problem with computer recognizing Audio Microphone.
Check if you selected the mic as the default audio input on the respective programs.
Aug 07, 2008 | Samson Audio C01upak C01u Microphone and...
GTrack producing NOISE and not catching audio from even 20cms.
Did you check the record levels on the software you are using.
Sep 14, 2007 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
657 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
