Question about Samsung Televison & Video
Problem with light effect function and energy saving function
Light effect will turn off but returns to on after about 30 mins. Energy saving function will go to high but returns to off when the light effectcomes on again after about 30 mins.
Still trying to fix it
Posted on Jul 28, 2008
I have a Samsung 55in curved TV. It has auto dimming. In the evening with the lights out it dims to where it is difficult to see the picture. Can I get rid of the auto dimming?
If the brightness on your TV changes automatically (randomly dims and brightens), you may need to adjust the:
  • Eco Sensor function.
  • - And / Or -
    • Energy Saving function.
    The Eco Sensor and Energy Saving functions adjust the brightness of the TV to reduce power consumption.
    • When you set the Energy Saving function to Auto, the TV changes its brightness automatically depending on what you are watching on the TV.
    • When you set the Eco Sensor to On, the TV changes its brightness automatically depending on the brightness of the room.
Oct 18, 2015 | Samsung Televison & Video
Tip
Make Your Pool Green!
Energy Efficiency <i>Make Your Pool Green!</i><br /> Pool owners LOVE green pools. Crazy statement if the "green" you're thinking about is unclean, algae-filled water. But when "green" means eco-friendly, a "green" pool is something homeowners should aspire to have in their yards.<br /> Energy Efficiency - Why? Why should I build or upgrade to an energy efficient pool?<br /> <ul> <li><b>1) Reduce Costs:</b> You'll save money. Energy-efficient pool appliances always pay for themselves in reduced electric bills, and then continue to save money for years to come. By choosing pool equipment such a variable speed pump or pool cover, and by establishing good habits like lowering the pool heater when not in use and proper preventative maintenance, costs to a pool owner can be greatly decreased.</li><br /> <li><b>2) Cuts down on energy waste and saves water:</b> Almost all of a pool's heat loss-about 95 percent-occurs at the surface, mostly through evaporation to the air and radiation to the sky. By using a pool cover to prevent heat and water loss, the amount of chemical water treatment will also be reduced. A multispeed or energy efficient pool pump can also significantly reduce the power consumption of a swimming pool by over 65%.</li><br /> <li><b>3) Tax incentives and rebates:</b> Did you know that some states offer tax incentives and rebates for homeowners that purchase energy efficient pool appliances? Check to see what incentives or rebates are available in your state..</li><br /></ul> Energy Efficiency - How? With a combination of pool products and good preventative maintenance habits, you can improve the heating and energy efficiency of your swimming pool.<br /> <ul> <li><i>Pump Efficiency-</i> You can save energy and maintain a comfortable swimming pool temperature by using a smaller, higher efficiency pump and by operating it less. On average, an energy efficient pump will use 30-45% less energy than that of a standard pump. The difference over a season can be immense. Pumps now come in two-speed, four-speed, and variable-speed models, so you can turn the speed down for regular daily use saving a lot of energy, and use higher settings for more thorough, less frequent cleanings. New energy-efficient pumps also move the water more efficiently for further savings. Since pumps circulate the water to keep it clean, the better they work, the less a filter has to work. <ul> <li>The <a href="http://www.pentairpool.com/pool-pro/products/pumps-inground-intelliflo-vs-3050-vs-svrs-variable-speed-pumps-76.htm">Pentair IntelliFlo&reg;</a> High Performance Pump is the world's smartest swimming pool pump. Its onboard computer and intelligent software automatically calculate and program the minimum flow requirements for every pool task - filtering, heating, cleaning, spa jets, water features and more - to optimize performance and minimize energy use. As functions/tasks change, IntelliFlo&reg; self-adjusts to maintain optimal flow rates for further energy savings.</li><br /> <li>With the <a href="http://www.haywardcanada.com/inground/products/pumps/EcoStar.cfm">Hayward EcoStar</a> family of pumps, money flows back into your pocket. EcoStar is the industry's most energy efficient variable speed pump, thanks to a super-efficient permanent magnet, totally enclosed fan cooled (TEFC) motor and industry leading hydraulic design. Tests prove that EcoStar can save you up to 90% on energy costs compared to ordinary single speed pumps. EcoStar matches pump flow to a pool's needs, versus running at full power 100% of the time. It's fully programmable with a self-contained 24-hour clock and up to 8 custom speed and timer functions that allow EcoStar to manage flow throughout the day. Whether used in new construction or aftermarket applications, EcoStar is the perfect choice.</li><br /> <li>Pentair has a calculator that you can use to <a href="http://www.pentairpool.com/pool-owner/resources/calculators/pool-pump-calc/index.html">calculate your energy savings</a> using an energy efficient pool pump.</li><br /></ul></li> <li><i>Pool Covers-</i> A good pool cover will save energy and water. It can keep the water in your pool an average of 10 degrees warmer, which can cut summertime pool heating costs by up to 90 percent. A cover reduces water and chemical evaporation by up to 70 percent, saving nearly a thousand gallons of water per month. A cover also helps keep your pool clean, which means you'll have to run your filter pump less often, saving even more energy.</li><br /> <li><i>Water temperature efficiency-</i> In addition to a pool cover, there are other ways to help keep the cost of heating your pool to a minimum while you still enjoy a comfortable water temperature. Make use of solar energy by locating your pool in the sunniest part of your yard. If possible, screen it from the cooling, prevailing wind with existing structures such as the house or garage, or add a solidly built fence as a windbreak. The water temperature you desire for your swimming pool not only affects the size of the pool's heater, but also your heating costs if use a gas or heat pump pool heater. Heating your pool with solar energy is by far the most energy-efficient method. If you buy a gas or electric heater, check the yellow-and-black Energy Guide label on the appliance. It shows relative energy-efficiency according to tests by the US Federal Trade Commission (FTC). Pool water temperatures typically range from 78&ordm;F to 82&ordm;F. The energy consumption for each degree rise in temperature will cost 10%-30% more in energy costs, depending on your location. In warmer climates, this percentage is higher because of the relatively low cost of heating a pool at 78&ordm;F.</li><br /> <li><i>Timers-</i> Buy automatic timers for both your pool heater and pump. This will allow you to run them in several short cycles during the day, which is more effective than running them once continuously for several hours a day.</li><br /> <li><i>Preventative Maintenance-</i> Maintain efficient daily operations. Turn down the pool heater when the pool is not in use and maintain appropriate water temperatures when in use (78&deg;-80&deg; for active swimming, 82&deg;-84&deg; for recreational use). Raising the water temperature just 1&deg;F can costs an additional 10 - 30%, depending on your location. Keep a thermometer in the pool to help determine the temperature that is best for your pool and mark the "comfort settings" on the thermostat dial to avoid accidental overheating. Backwash the pool filter only as much as necessary to avoid wasting water and energy and be sure to keep drain systems clear to allow the free flow of water. By far, the most energy efficient lights you can get for the pool are LED or solar powered.</li><br /></ul> Energy Efficiency - Not just for pools! It is also possible to make your spa energy efficient. Portable spas are more energy efficient than in-the-ground spas because they are better insulated and usually have covers. If you have a typical portable spa, your heater will heat water 10 degrees in about 8 hours. If you use your spa once a week, lowering the temperature 3 degrees when not in use will save you approximately 5-10% of your spa heating costs; if you use the spa less often, your savings could be even greater. Don't run the jets unless you are using your spa. The mixture of water and air is great for relaxing the muscles, but it cools the water quickly. Spa covers are important. Be sure to leave the cover on until you are ready to use your spa and replace when you're finished. Remember that the heat that escapes is the heat you must pay to replace.
on Mar 17, 2011 | Pool & Spa
Tip
Tax Incentives for Heating and Air Conditioning
The passage of the American Recovery and Reinvestment Act of 2009, consumers are able upgrade to more energy-efficient heating and air conditioning equipment. They can start saving on energy bills right away, and you may also save on your taxes next year. For your home, these benefits can include lowering home energy bills, increasing your indoor comfort, and reducing air pollution. These programs are helping savvy consumers’ lower energy bills in their home. The energy-efficient products that are eligible for the new federal tax credits can lower the amount of federal income taxes that many taxpayers must pay Uncle Sam.
There are some new potentially lucrative tax incentives for energy-efficient and renewable-energy home improvements. These may offer some consolation to many homeowners who feel they are getting forgotten with the government's various economic stimulus efforts.
There is a $1,500 energy-efficient credit, which currently will last only last two years, meaning consumers will have to find a way to spend this money during this economic downturn. Homeowners now have a new opportunity to lower their energy costs and save on their 2009 federal income taxes by making specific energy efficiency upgrades to their homes.
There is also a new tax credit that will be effective 2009 through 2016 for 30 percent of the cost of a qualified geothermal heat pump. This can be for up to $2,000. These caps do not apply to certain alternative energy systems like geothermal heat pumps, solar water heaters, wind power, or photovoltaic systems. The benefits for installing some pricier solar technology, small wind-energy systems or geothermal-well systems can include a tax credit of 30% for qualifying expenditures with no upper limit through 2016. In order for you to claim your credit, the energy efficient improvements you must use qualifying Energy Star rated products and they must be started up sometime between from January 1, 2009 through December 31, 2010.
By doing your research and talking with your heating and air conditioning professional you may be able to save a substantial amount of money and get some great home improvements at the same time.
on Dec 26, 2009 | Heating & Cooling
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
Remove screensaver from TV
Hello
You are refering about energy saving function I thinks. To energise this function, surf through its menu and come towards energy saver.
This power saving feature reduces the backlight
brightness level. The options are:
OFF-the feature is off and the power consumption
is normal.
LOW-power saving level is low and the backlight
brightness level is lower than normal.
HIGH-power saving level is high and the backlight
brightness is set to the lowest level.
1 Use the CURSOR Up or Down keys to highlight
Energy Saver. Press ENTER.
2 Use the CURSOR Up or Down keys to select Off, Low,
or High.
NOTE:The Energy Saver settings level varies with
the Picture / Sound mode.
OK.
Feb 20, 2011 | Sanyo 42 in. LCD TV
Tip
Air Conditioner SEER Seasonal Energy Efficiency Ratio
Energy consumption for home air conditioning accounts for almost 5% of all the electricity produced in the USA. Energy Policy Act mandates minimum energy efficiency standards for commercial buildings, using research and standards developed by the American Society of Heating, Refrigerating, and Air Conditioning Engineers. Energy Star qualified central air conditioners have a higher seasonal efficiency rating (SEER) than standard models, which makes them about 14% more efficient than standard models. Energy efficiency specialists with certified training on retrofits and energy savings on both residential and light commercial units may enable you to save up to 50 percent on your air conditioning bills with the use of a high efficiency energy system. Substantial energy savings can be obtained from more efficient systems.
SEER (Seasonal Energy Efficiency Ratio) is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations.
The SEER rating is the Btu of cooling output during a typical cooling-season divided by the total electric energy input in watt-hours during the same period. SEER is related to the Energy Efficiency Ratio (EER), which is the ratio of output cooling in Btu/Hr and the input power in watts W at a given operating point and also to the coefficient of performance (COP) commonly used in thermodynamics. SEER rating more accurately reflects overall system efficiency on a seasonal basis and EER reflects the system’s energy efficiency at peak day operations. The higher the SEER number, the greater the efficiency of your unit. Therefore you will realize greater energy savings. The higher efficiency your product, the lower your long-term energy costs will be. Both central AC and air source heat pumps are rated according to seasonal energy efficiency ratio (SEER).
Before you consider upgrading your cooling equipment, the cheapest way to save money and energy from cooling is to reduce the need for mechanical air conditioning in the first place. Ask your contractor about a variable speed air handler, which will improve comfort and efficiency and allow continuous air filtering at minimum energy cost. Also, because ducts are often responsible for a lot of wasted energy, make sure you hire a contractor who knows about high-efficiency installations. If your central air conditioning unit is more than 12 years old, replacing it with an Energy Star qualified model could cut your cooling costs by 30 percent.
on Dec 14, 2009 | Heating & Cooling
Tip
Solar Air Heating - You Can Cut Utility Costs and Save Money
Solar energy is becoming very quickly recognized as one of the best alternatives to fossil fuels It is an abundant and renewable natural resource. It can be used to save energy in residential, commercial, and industrial settings. Solar technologies will use the sun's energy to provide heat, hot water, light, electricity, and cooling, for homes, businesses, and industry.
Many major advancements have been made in the solar technology fields over the recent years. Solar air heating is becoming more attractive than ever before now that it is becoming lower in cost and more efficient. Solar energy is easily the cleanest and most inexhaustible of any of the known energy sources. The many variations in energy prices have fueled interest in alternative fuels such as solar energy. Demand for solar energy has been increasing exponentially as heating, cooling and many other energy costs continue to skyrocket.
Solar air heating and solar water heating are two examples of solar thermal technologies which produce heat, but not electricity. Solar air heat is best suited for installation in new construction and existing houses. Solar panels for any type of heating should be placed on a south-facing pitched roof, free of shade. The angle should be between 20 and 50 degrees. They may also be mounted on an angled frame on the ground or on a flat roof. Solar air collectors (the devices that heat up the air using solar energy) can directly heat individual rooms. They also can potentially pre-heat the air passing into a heat recovery ventilator or the air of an air-source heat pump. Solar heating panels can be one of the most cost effective ways to reduce your utility bills. This will make a positive contribution towards a better environment. Solar air heating systems often use large bins filled with rocks that store heat (although this method is becoming rare due to problems associated with controlling moisture and mold growth in the rock).
Energy Policy Act has implemented a 30% tax credit for consumers who chose to install solar water heating systems. State and local government programs are now being put in place to encourage the use of solar energy. Cash incentives are available for those that integrate solar energy technology as an alternative energy source. The Department of Energy (DOE) is working to design even more cost-effective solar heating systems and to improve the longevity of the materials used in those systems. Other incentive programs now include offering homeowners tax credits for solar panel installations and for solar heating systems. With solar power you will save money, increase your property value, help protect the environment and help to create a more secure America by reducing our dependence on foreign energy fuel sources.
A great solar heating system will save energy, reduce utility costs, and produce clean energy.
on Dec 12, 2009 | Heating & Cooling
One of my five EJ500C timers controls 6 outdoor landscaping lights behind my house. I installed the energy saving (coil type) bulbs and, at roughly 15 minute intervals after the lights come on at dusk, the...
The EJ500C is designed only for standard incandescent lights, not chandelier bulbs, CFLs, etc. Replace it with the ST01C, and you'll be fine. Intermatic may even exchange it for you if you if you complain to them.
Feb 27, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Which programme saves the most energy?
yes a quick wash is for coloured clothes that have been worn once or twice and dont have bad stains on them.This quick wash will take between 30 and 50 mins to do a wash and is the best programme for the clothing that I have discribed ie: worn 1or2 times and no stains will save you on electric and water peter
Jun 09, 2008 | Zanussi Washing Machines
Open Questions:
Televison & Video Logo
110 people viewed this question
Henry  Thomas
Henry Thomas
