Question about Frigidaire FRS26R4A Side by Side Refrigerator
Compressor buzzes loud & frig does not get cold
Model FRS26R4AW6, 6 years old. Recently, frig & freezer get warm and compressor buzzes on and off. Not sure if I need a new compressor or recharge.
  • 487 Answers
That can also mean that the starter is broken.which will be a cheaper fix than a new compressor.Also the capacitor can be broken and that will give the same results.
Please click HERE for drawing and parts( #30 is starter #55 capacitor)
Posted on Jul 28, 2008
K68625FJBL01 KitchenAid Sidebyside Refrigerator Freezer compartment was not cold yesterday so I cleaned the dog hair off the coils and the freezer is still warm and fridge side is not cold enough now. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 29, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Amana frig model#scd25tw freezer and frig not cold enough
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Nov 28, 2010 | Amana Refrigerators
Here are the unit's issues: 1. freezer won't stay cold and 2, a loud buzzing sound can be heard periodically Any idea what's causing these defects Thank for any help you can offer
Sound's like the start relay overload on the compressor if you hear a humming and a click do not leave plugged in get new relay/overload at you local part store or the compressor winding will burn up and a new frig will occur message me if this is the sound and inconsistent cooling temp b4 you heard the buzzing and click take you model # to the parts store an easier repair which is good....
Aug 24, 2009 | Kenmore Freezers
Kenmore top freezer frig
check your start relay on compressor. If that doesnt solve it then you need a new compressor. This is all based on the facts the you said the unit is running all the time
May 27, 2009 | Kenmore 63182 / 63184 Top Freezer...
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
I have 10 year old Roper refrigerator. Frig is a
the thump is your compressor shutting off.you can try changing the rubber grommets but most likely your compressor is just going to be loud until it finally dies.
Mar 05, 2009 | Refrigerators
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Oct 31, 2007 | Refrigerators
Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Sep 29, 2007 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
123 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
