Question about Panasonic Heating & Cooling
I have a panasonic Cs-1203kr reverse cycle air conditioning unit that is not blowing hot air. Does this mean that the heating element is not working, or that I am not selecting the correct settings. There is no operating manual so I don't know what the symbols mean.
  • 49 Answers
SOURCE: reverse unit. Heater only blows air, not warm air
If you have a reverse cycle unit (heat pump) your compressor and your fan should be running. You need to determine if your compressor is running.
Posted on Nov 08, 2007
ACTECH
  • 80 Answers
SOURCE: intertherm heat pump
FIRST YOUR OUTSIDE UNIT PROVIDES HEAT BY USING A REVERSING VALVE TO CHANGE THE REFRIGERANT FLOW.THERE IS NO HEAT STRIPS OUTSIDE SECOND YOUR EMERGENCY HEAT TURNS ON ELECTRIC ELEMENTS INSIDE YOUR AIRHANDLER UNIT.IT SOUNDS LIKE SOMEONE HAS WIRED YOUR UNIT WRONG OR HAS THE THERMOSTAT SET IMPROPERLY.WHEN THE HEAT PUMP CANNOT SATTISFY THE SETPOINT THE THERMOSTAT IS SUPPOSED TO TURN ON YOUR ELEC. HEAT UNTILL THE LOAD HAS BEEN REACHED AND THE HEAT PUMP CAN CONTINUE TO MAINTAIN IT.
Posted on Nov 29, 2007
  • 30 Answers
SOURCE: panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
pilungu
  • 30 Answers
SOURCE: my heat unit will not blow hot air unless we go
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Posted on Nov 07, 2009
Testimonial: "Thank you. My home warranty tech is coming out monday and i want to make sure he checks everything. this will be the 2nd time he has been out."
  • 534 Answers
SOURCE: Panasonic CS/CU-A242KR Air conditioner leaking water
OK lets see what we can help you with here. The condensate drain is clogged. There are a couple of ways to clear this clog so lets give it a try. If you know where the drain for the a/c is located outside (usually by the outside condenser unit) it will be a pipe that is just sticking out of the side of the house, if you find it take a wet/dry vac and place it on this pipe and turn the vacuum on and make a seal with your hand this should unclog the drain. If you don't find this pipe outside the house then go to the furnace and you will see at the bottom of the furnace a pipe (PVC) white, this is the drain for the unit inside. Take the wet/dry vac and have it at the ready in the event the clog is further down the line than at the furnace itself now the fittings on this pipe should not be glued together due to the ability to access for this very purpose. Take the pipe apart at one of the fittings and place the wet/dry vac on the end of the pipe towards the furnace and using your hand make a seal and evacuate the line. Do this to both sides since you don't know where the blockage is. If you are unable to separate the pipe at any fitting you will need to cut the pipe and at the spot of the cut you will need to repair it with a sleeve. Remember that the drain pipe is plastic and is made of pvc so you can get a repair coupling from any home improvement store for this repair.
Hope this helped you some
Dave
Posted on Feb 21, 2010
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Goodman minisplit flashes on pre. Def. Wont start
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Repair Tamarac
Apr 07, 2015 | Goodman Heating & Cooling
When set to heat it blows out cool air.
Chances are your portable unit is a reverse cycle unit...If so, the leaving air temp in heating mode is not usually much warmer than room temp with 85 degrees F just about the maximum under PERFECT design conditions. A small portable in a large cold room may only be discharging 75 degree air, which is going to feel cold.
If your unit is NOT a reverse cycle unit, the heating source (probably electric resistance) is either not coming on at all or a portion of it is not coming on due to a defective element, burnt wire or a control issue.
Jan 08, 2015 | Amcor AL10000EH Portable Air Conditioner
Panasonic CS-A12DKD Air conditioner does not
This could be an inoperative reversing valve or bad reversing valve solenoid coil.
Oct 31, 2013 | Panasonic Heating & Cooling
Air conditioner is blowing hot air, it was installed 1995 , the top switch option is CONT FAN AUTO and bottom switch is HEAT OFF COOL and on the right is a dial from 10-30
First of all, what do you mean by hot air? DO YOU REALLY MEAN ROOM TEMERATURE AIR THAT JUST DOES NOT FEEL COLD? If this is a heat pump system, we need to look at it differently than if it is a gas or oil fired heater. Next, the thermostat control that says "cont.fan auto"----- this actually means FAN switch to be in AUTOMATIC RUN or CONTINUOUS RUN mode. Leave it in auto mode and forget that it is there; this little switch confuses a lot of people. The dial that says 10-30 is centegrade temperature that translates to 50-87 degrees farenheit. In order to get air conditioned (cold) air, you must have thermostat fan switch on auto, the heat/off/cool switch on cool, and the 10-30 dial on 20 or 21 (68-70 f.) assuming the room temp is at least 72 degrees f. or higher. If you still do not get cold air, then there is a problem with the cooling circulation system which can be tripped circuit breaker to outside compressor unit, loss of freon refrigerant, bad control such as relay or reversing valve in outside unit, stuck heat sequencers or heat element relay that are giving you heat at the same time giving cold if it is a heatpump system. You will need a skilled service person to determine these problems. Goodluck, Macgivor
Nov 09, 2009 | Cell Phones
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
Nov 07, 2009 | Ruud Central System Air Conditioner
My air conditioning blows hot air only, nothing
ok if unit is split system two piece check to see if out door unit is running fan and compressor the air coming out of the fan should be about 20 deg warmer than out door temp if not compressor not running check the capicitor to see if swelled up on top if so bad if unit has electric heat strip a heat relay may be stuck and you are running aug heat to check this pull disconect on out door unit and see if heat is out of vents if heat pump reversing valve may be bad hope this helps
Jul 04, 2009 | Heating & Cooling
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Model# 86592110 - 65921
The heating element DOES cycle on and off through the cycling of the high limit thermostat. When was the last time you inspected the dryer vent and/or inside the dryer for lint? This sounds like you could have a couple of possible issues. Either you have a dryer that can't breath (Meaning, the vent hose is clogged from where it leaves the dryer to the vent outside. Or...the dryer may be clogged inside the air baffle inside the dryer where the lint screen goes.), or you could have a high limit thermostat that is malfunctioning. Now...the dryer will get hot to some degree, but it shouldn't be excessive. Here's a recommendation:
1. Remove the dryer vent hose from the dryer and turn the dryer on. Is the air leaving the dryer forceful and warm? (it should measure about 140 degrees F) If so...you probably have a clog or kink in the ducting somewhere between the dryer and where it exits the house. If the air is weak and cool, you will need to inspect your dryer interior to find what is obstructing the air flow. Rodents are notorious for building nests inside the event line or air baffle.
2. Can you access the heating element so you can see it? Start the dryer with the casing removed so you can watch the heating element. The element should glow red, but not so bright that it glows like the sun, and it should cycle on and off. If it glows continuously, the high limit thermostat is a likely suspect and should be replaced. (NOTE: It is recommended that you replace the high limit thermostat and thermal cut-out at the same time. Some manufacturers will sell the two as a pair).
HINTS: If you have a lint screen in the door, you should be able to access the heating element by removing a panel under the door. If your lint screen is on top of the washer, you will have to remove the rear panel of the dryer to see the heating element.
If the dryer is left to run in an overheat condition, the thermal cut-out and/or heating element will eventually blow. It is recommended that you inspect the dryer to see what is causing your current problem.
CAUTION: Always unplug the dryer if you are servicing the inside of the unit. Dangerous voltages are present even with the unit turned off. Also, unplug the dryer if you have to remove the rear panel. The 220VAC terminal is directly behind the panel and can cause electric shock if touched.
I hope this information helps you. Do your homework and post back if you need any further assistance.
Feb 02, 2008 | Kenmore 659 Electric Dryer
Heating & Cooling Logo
102 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
