Question about GE Microwave Ovens
I need to order a new turntable for my microwave oven. The model # is JVM1871SK04. I saw two and one was a good bit cheaper then the other. I am not sure which one I should order.
    Scholar:
  • 135 Answers
Hey, it's just a piece of glass. If it's listed for it, and it's cheaper, buy the cheaper one
Posted on Jul 28, 2008
My kitchenaid microwave will not heat in microwave mode. In fact the turntable starts and stops and the display blinks intermittenly. In convection oven mode everything works fine - It heats, turntabl
The magnetron is the main part that gives out microwaves to heat the food. As the convection bit is working this points towards the microwave bits.
The magnetron has a main diode, fuse and transformer to run the microwave bit, any of these could be faulty. A word of warning though, there are extremely high voltages inside microwaves, even when unplugged in the main capacitor. Also to repair this section you will need to be a fully qualified engineer to even order parts for this.
Find a microwave technician who can repair for you
Nov 04, 2014 | Microwave Ovens
Turntable stopped working (yes, I pressed the turntable on/off button)
It all depends on your model number of course, but if JUST the turntable is failing, it may just be a defective turntable motor or coupler.
If your internal cooling fan and/or inside / cavity light is defective, too, it may be the internal fan motor, a door switch, or a relay on the control board.
We repair those and can offer more free advice with the full model number and a little bit more detail about what's working, what's not, and when.
You can find handy exploded views and order parts by model number here.
Nov 27, 2012 | GE JVM1850 1000 Watts Microwave Oven
Turntable has stopped revolving
Unfortunately unless your are under warranty there is not much you can do. The table is driven with plastic gears and these wear or break. You can call a repair shop and if they happen to have the gears from the same model they might be able to fix it cheap enough. Otherwise it might be cheaper to get a new one to get it working again.
If it works other than this you can get a wind up turntable. Not as good as the driven one but these are cheap.
Jan 24, 2011 | Panasonic NN-T583SF Microwave Oven
Not heating
most likly it is the mag and the diode. it should be covered for ten years after you bought the unit so check into that. you will have to pay a ge authorize servicer to replace it though but parts should be covered and still cheaper than a new microwave
Jun 02, 2010 | GE Adora DVM1850 Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
What do you call the three pronged plastic "thing" the plate sits on inside the microwave? It started on fire and I need to order a new one for a Sharp microwave model # R1420B
turntable guide with rollers...Turntable Support,  others... Here's a TN supplier: http://microwaveglasstrays.com/shop/-c-44_58.html
Jul 15, 2009 | Sharp R-510HW Microwave Oven
Hi I have an Emerson microwave oven MW8998B. The turn table will not rotate while cooking. The smaller bags of popcorn just burn the bag. Does this need a repairman or can I fix it myself. Also, I am able...
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
May 13, 2009 | Emerson Black Microwave Oven
JVM1871sk04 GE XL 1800 Microwave
PS50009 is the part number for your glass plate that will cost you $60.00, go to partselect.com, simply put the part number... and place an order ....you know what to do next...
cheers pls mark my solution
Nov 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
OTR microwave turntable won't rotate
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If not, please post your brand and model.
It's probably the motor, but possibly the coupler.
One quick check is to remove the turntable and support / roller ring and try to turn the coupler. It should be a little hard to get started, then you should hear a whirring sound, not a clicking or grinding, which would indicate a bad motor.
If the coupler turns loosely with no resistance, then it's probably bad.
Here is my text on replacing couplers, which had steps which are necessary when replacing motors. Note that if yours is a built-in model, ignore the part about turning it on its side *grin*
NOTES ON REPLACING TURNTABLE COUPLERS
Copyright 2007 by William E. Miller - MicrowaveDisplay.com
UNPLUG THE OVEN FROM THE WALL FIRST OR YOU WILL EXPOSE YOURSELF TO LETHAL VOLTAGES!
Note that I am not encouraging you to work on electrical items if you are not qualified, and I assume no liability for any consequences of your decision to do so.
When replacing the turntable coupler on most models, it is necessary to loosen or remove the screws that mount the turntable motor to the bottom of the chassis.
It is usually easier to do this with the microwave oven on its right (heaviest) side because you will need two hands for alignment.
Be sure to put a towel or similar cushion on the work surface to avoid scratching the oven wrapper (oven cover) or the work surface.
It is not necessary to remove the wrapper or the wires from the turntable motor itself, but you may need to remove a small metal duct covering the turntable motor if your oven has one.
It should only be held on by one or two screws.
Although a broken coupler may come out easily or even fall out, the new coupler will not go in without at least loosening the turntable motor.
Look at the hole in the new coupler. You'll notice it has (most do have) a flat side to it. That flat side will line up with the flat side on the motor shaft.
When the old coupler is out and the motor is loose, you can ease the new coupler in the hole with one hand while turning the coupler very slightly back and forth as you gently push the motor toward it. Do not force the part in.
When the coupler has mated properly with the motor, you should feel it go in.
Be sure it's right, or you may break the new coupler or bend the mounting ears of the motor when you attempt to tighten the screws.
Reassemble in reverse order.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 05, 2008 | Microwave Ovens
Microwave Ovens Logo
26 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
