Question about Canon ZR800 Mini DV Digital Camcorder
I have a Canon zr80 camcorder and it has started to refusing to keep the tape in the machine. this happens as soon as you turn it on. What is wrong?
  • Sepheria Mar 13, 2009
    I have the Canon ZR800 and as soon as I open where the tape goes it starts beeping and the eject icon on the screen flashes red. If I put a tape in it, it pens right back up making the same beeping sound and tells me to remove the cassette immediatly. Any clues on what I can do?
I have sime probleme, if you have solution for this probleme please send me the solution at this adresse aitmouhoub_s@yahoo.fr
Posted on Oct 23, 2008
I just closed it and where it says do not push i pushed and it just worked
Posted on Aug 14, 2009
Hi my sony CCD-TRV57E keeps ejecting the tape, and
My SONY CCD-TRV57E isn't recording or any function.seem to be working. Bty ok. In view finder I'm getting "SP C:31:22" also a symbol like and inverted coathanger with a line thru it and a + sign on top.
May 15, 2010 | Canon ZR80 Mini DV Digital Camcorder
Macbook not recognizing camcorder
I had this problem when first plugging in my Canon zr80 to my Mac. What I did first was (if you have it) open up the program Imovie in you're applications menu. Then plug the firewire cable into both the camera and computer. Turn the camcorder on and set it to play(VCR). Once this happens you should see a "DV in" on the camcorders screen, followed by a blue window on you're computer. The rest should be easy.
Jul 01, 2009 | Canon ZR800 Mini DV Digital Camcorder
Canon zr300 ejects tapes
http://www.fixya.com/support/t985270-cassette_loading_problem_in_canon_zr200
I "smacked" my ZR300 as instructed on this site and it worked. Good luck!
littlequeen
Nov 02, 2008 | Canon ZR80 Mini DV Digital Camcorder
Canon Elura 65 Camcorder Refuses to Load Mini DV Tape
Try a different tape in case the take up isn't working in the previous tape.
Clean the tape heads with a tape cleaner in case there is buildup on the pinch rollers causing the tape to jam or slip.
If those solutions don't work, you should take it into a repair shop to have a closeup view as to what the problem is unless you see something obvious like a spring broken or loose or a bent piece or foriegn objects in the deck.
Aug 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Zr80 camcorder
Push down where it says "Do not push down here"!
Jul 31, 2008 | Canon ZR80 Mini DV Digital Camcorder
Canon E520 camcorder
the head needs aligned.. the cassette compartment is out of balence
Feb 28, 2008 | Canon ZR80 Mini DV Digital Camcorder
Canon ZR80 Blank Screen and more
Call 1-800-828-4040.....there is a defective chip that needs to be replaced and Canon will fix it for free. They even sent me free shipping lables as well....
Dec 31, 2007 | Canon ZR80 Mini DV Digital Camcorder
Gray lines on playback
Try using an $8 head cleaner for 10 seconds. That might be the solution or if it's a used tape, the speed isn't limked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that.
Dec 26, 2007 | Canon ZR60 Mini DV Digital Camcorder
Camcorder ZR80 saying remove cassette, won't record or play.
when you put cassette try to see the take up left side weather it rotating?if no try to rotate with your finger.may be there is a bend on that.
Nov 25, 2007 | Canon ZR80 Mini DV Digital Camcorder
Hello - Canon ZR80 - auto shut off
If you're trying to use the camera as a webcam, just remove the tape. The auto power-off is a safety for keeping the tape from getting damaged.
Nov 18, 2007 | Canon ZR80 Mini DV Digital Camcorder
Canon ZR800 Mini DV Digital Camcorder Logo
186 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Chris Phillips
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
