Question about Bosch Washing Machines
Our bosch nexxt 100 washer is leaking/dripping
The pump is clog if you remove the circular cap bottom right of washer you will find an little propeller make sure it spins freely if it does not you have a problem with the pump.
Posted on Oct 12, 2008
Bosch nexxt 100 washer keeps getting water in drum
Check the way the waste pipe is connected to sink drain,could be purge back from here or could be faulty/ leaky fill valve,
Oct 31, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
How to replace a drain motor on a bosch nexxt 100 series washer
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Mar 18, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Replacing a gasket on a bosch nexxt washer
For parts look in Fixya. For changing go to YouTube, great videos to show you how.
Click helped, if helped.
Mar 14, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
How I can clean fliter for washer machine bosch nexxt 100 series
just unscrew the filter plug located usually front bottom of machine.
Dec 13, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 500 WFMC3301UC Front Load Washer is leaking water somewhere inside the unit. It is only doing this from the hot water source. All connections are tight and there are no external leaks. The cold...
It sounds like it may be the hot water valve, the valve itself may be leaking or the water pressure from your hot supply may not be high enough to 'lock' the valve fully when not energized. The second problem could be rectified by using a 'y' piece splitter on you cold supply and running both valve on cold water,
Link to parts diagram valve is position 407.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFMC3301UC%2f16&ESHOPTYPE=S
Jul 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing Machines Logo
204 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
