Question about Toshiba Satellite R10-S802TD Tablet PC
Event repetition, as if key stuck
Reasonably regularly (a few times a day), the laptop will start repeating an event until I press Alt.
e.g.
(1) when booting, before loading Windows, it gives the keyboard buffer full sound repeatedly.
(2) I had a dialog box open when I got called away from my desk. When I returned, it was repeatedly opening & closing one of the drop-down lists.
(3) using the laptop in tablet mode, I pasted some copied text via the menus, using Edit > Paste. It then proceeded to repeatedly paste the text.
(4) I inserted a new page into a Visio. It then - well, you guessed it - repeatedly created pages.
Any ideas? A full virus scan using AVG Free found nothing. Windows XP Tablet PC Edition 2005, Version 2002 SP 2.
Thanks in advance.
I think, you have a problem whit keyboard, may be Ctrl key is failed or is broken
Posted on Dec 06, 2008
Hw to get safe mode off a Nextbook tablet
To get out of Safe Mode, please try the following.
1. Touch and Hold the "Power" key.
2. Tap "Power Off".
3. Once the tablet is off, Touch and Hold the "Power" key again to restart.
The tablet should now be out of "Safe Mode".
If the "Safe Mode" is still running after you restart your phone, I would then check to make sure your "Volume Down" button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, "Safe Mode".
If that doesn't work try this...
Use the "Status Bar" to turn off "Safe Mode'. Pull down (swipe) the "Status Bar" of your phone. Now tap the "Safe Mode" button. This should turn "Safe Mode" off. Now your phone will automatically restart, so that it boots up out of "Safe Mode".
And lastly...
If you want to get rid of/disable "Safe Mode".
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe Mode: OFF" or something similar.
4. If you wanted re-enable it, simply repeat the steps above, and you should see "Safe mode: ON" rather than off.
Mar 25, 2018 | Nextbook Tablets & eReaders
How do you Stop Safe mode,on the tablet?
Stop Safe mode on the tablet Google Search
2. Tap "Power Off".
And lastly...
Mar 07, 2018 | Tablets & eReaders
How i recover my infotmic tab
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
Feb 04, 2015 | Tablets & eReaders
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Error 95292
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
Dec 22, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
Computer wont come on
Did you installed the fjsecs Security Panel Application????...
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/Security.htm
Read this manual, maybe can help you.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/T4220_UG_B5FJ-4091-02EN-00.pdf page 26
To unlock the machine is completely necessary that you remind the password...
Just pres the display buttons in the order that you selected in the program.
http://static.phing.com/listings/48/481970/2882-8dc5j0_l.jpg
The buttons next to the power button at the right of the display.
There is a microphone symbol next to the buttons....
1 = a and arrow down
2= b and arrow up
3= rotate screen button
4= fn button
ent = alt.
If you selected http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/images/Screenshots/Image5.jpg
Example:
If you checked the boxes 1234 pres the buttons 123and4 at the same time.
next press ent (ent is next to power button)....
when you press any button that make a beep sound...
If the pass is wrong it will beep constantly for one minute..
other example: 1 - 2 - 14 - 4
in the first just 1 press 1
in the second 2 press 2
in the third 1 and 4 press 1 and 4 at the same time
in the fourth 4 press 4
finally press the button ent.
I hope you can access to your laptop....
Feb 06, 2012 | Fujitsu LifeBook T4220 Tablet PC
How to delete apps on an ipad
To remove/delete an app from your iPad, do the following:
  1. Press the icon for the app until all icons start to wiggle. Note, press and hold your finger down, don't just tap it.
  2. When the icons start to wiggle, a small X will appear in the top-left corner of all app icons. Tap the X and you will get see a prompt asking you to verify that you want to delete the app.
  3. Click "Delete" and the app will be removed.
Note: The deleted app will remain in your purchase history in the event that you ever want to re-install it.
Dec 06, 2011 | Apple iPad 32 GB WiFi Tablet PC
My sony viao pcgn505a is very slow when i open it. It has also a samok virus and very slow internet connection. Please help how to reformat it and where to get drivers for it. Thanks.
I would suggest try avoiding formatting. Because if you do that, then the next problem you will face is to find, download and install all the drivers.
If you are using the Genuine Windows operating system, then download 'Microsoft Security Essentials' for free from the Microsoft website. This should take care of your viruses.
Second get the latest Service pack provided by Microsoft and this should update the drivers.
And basic things, like removing unnecessary files, Defrag you hard disk, etc should also add up to the speed.
Mar 25, 2010 | Tablets & eReaders
Taskmanager popup
Let's start as simple as possible:
Do you have a loose connection / glitch at the power-connector? Check and solder (link to manual for disassembly is further down in this document)
To me this looks like a stuck key (not necessary one on the keyboard):
create live-usb-ubuntu:
1. download and burn ubuntu 8.10 to cd.
2. boot _any_ computer with it, connect >1GB USB stick.
3. System --> Administration --> Install to live usb
4. Boot from live-usb-stick that you just created
5. open terminal (Applications --> Accessories --> terminal)
6. paste this: sudo apt-get install xev
7. paste this: xev
8. hover with mouse over white box
9. make sure not to press any keys or move the mouse. Now flip the screen or try to recreate a situation in which the task manager would pop up in windows.
10. what's the output in the terminal window? Try to pinpoint exactly how and when the events are generated.
There should be no event generated, when you physically flip the display (which means you don't have to replace the hinge).
Press every single key you can find on the laptop. Verify that each key generates exactly one event.
If you find that there is a series of events generated without any key pressed, try to clean the malfunctioning key. (Service manual for disassembly)
It might possibly be a broken hinge (20USD). Flipping the display and pressing soft keys (Q, rotate, e) does not generate events in xev. Any other button does.
Sep 29, 2008 | Compaq tc4200 Tablet PC
Toshiba A200 laptop screen
if you got ATI i think its shortcut:
ctrl + alt + up to get him back to normal.
Jun 15, 2008 | Tablets & eReaders
Toshiba Satellite R10-S802TD Tablet PC Logo
216 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
