I am getting this error when I attempt to open my staff directory (where the data is supposed to show up on the website): Microsoft OLE DB Provider for ODBC Drivers error '80040e10' [Microsoft][ODBC Microsoft Access Driver] Too few parameters. Expected 1. /wdmontm/asp/staff_select.asp, line 50 Line 50 is: rsSiteData.Open strSQL, adoCon How do I find a solution? Thanks, CAT
    Genius:
  • Computers & ... Master
  • 1,056 Answers
Talk to the person that created the database for the website.
The problem is in the program parameters and not something that can be control by a person viewing it.
Posted on Jul 28, 2008
I have a database in mdb format that will not open. When I try to open the file I get an error: The Microsoft Access database engine stopped the process because you and another user are attempting to...
You can use Recovery Toolbox for Access developed for recovering data from corrupted Microsoft Access databases. The MS Access recovery tool is capable of repairing MDB and ACCDB database files.
For more: https://access.recoverytoolbox.com/
Dec 01, 2015 | Microsoft Office Professional 2007 Full...
The Windows Search service stopped working on my Win 7 machine. Said indexing was not turned on. I used event viewer and found the following error message: The Windows Search Service has failed to...
1) Insert your flash drive
2) From the Start Button, type "services.msc" in the "Search programs and files" box
If prompted for Admin Access, answer yes
3) Scroll down to the "Windows Search" service, select it, and click Stop.
4) From the Start Button, type "regedit"
5) Browse to [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Search]
6) Verify that the values DataDirectory and DefaultDataDirectory are set to %ProgramData%\Microsoft\Search\Data\
7) Remove the flash drive
8) Reboot (or restart the Windows Search service)
Jul 26, 2011 | Microsoft Computers & Internet
How do i get a personal support tech for datacard 150i?
I have a problem at work editing the project properties
From the menu bar, select Edit and then Production Form Properties. The Edit Production Form Properties dialog box opens.
data source for select OLE DB provider and source
when Click on the Choose button this message appears error occurred the selection or configuration of adata source
Oct 19, 2010 | Computers & Internet
Error 2123 appears when loading rosetta stone
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
Feb 20, 2010 | Rosetta Stone Japanese Level 1 & 2 for...
I am trying to access the message board of web site. the error message is sql erro (msyq14)Too many connections [1040] An sql error occurred while fetching this page. Please contact an administrator if...
This is not something you can fix. The mySQL Server is only set up to deliver so many connections for the number of users X the number of objects needed. Several weeks ago the db staff must have added new objects to the system, exceeding the number of available connections. You need to let the website technical staff know this is happening. They did not test their changes adequately.
Jul 10, 2009 | Microsoft Press Internet Explorer 6
Getting "Unspecified Error" While Opening an Excel File by using OLEDB Connection. I am Using Follwing Code to Open the Excel File. string connectionString = @"Provider=Microsoft.Jet.OLEDB.4.0;Data...
Hello, you are probably using an incorrect connection string.
Usually you can use a datasource (such as Access Database) directly in an excel document. If that is what you are trying to accomplish here check out the following sites:
Plug into your data Connecting Excel to an Access database Office Blogs
OR:
Connect an Access database to your workbook
If you are writing software application, from within Visual Studio (depending on the version) go to the left-hand side bar to "Server Explorer" -> "Add Data Connection" -> Click on the "Change" button of the Data Source part and select the appropriate Access Data Source -> Click the "Advanced" button.
After that, you will see in the bottom textbox, the appropriate connection string for the JET.OLEDB Connection Provider.
This is shown in the image below:
fews-khtxegu4lrzhmquqt25la0x1-4-0.png Alternatively, you can find more information about your connectivity string in the link below:
https://www.connectionstrings.com/microsoft-jet-ole-db-4-0
For usage of an oledb connection object you can find info here --> https://msdn.microsoft.com/en-us/library/system.data.oledb.oledbconnection(v=vs.110).aspx
Mar 30, 2017 | Microsoft Computers & Internet
Microsoft OLE DB Provider for ODBC Drivers error '80040e31' [Microsoft][ODBC SQL Server Driver]Timeout expired . How to solve this problem.
There are several things that could cause this to appear....Try this link: http://social.msdn.microsoft.com/Forums/en-US/sqldataaccess/thread/cccea79b-f7c8-4fd4-85b8-7182d92d8f91/
If that doesn't answer your query, please consult this list and apply the fix that most closely relates to your particular circumstance...
http://search.microsoft.com/results.aspx?mkt=en-US&setlang=en-US&q=Microsoft+OLE+DB+Provider+for+ODBC+Drivers+error+%2780040e31%2
I hope that helps to clear it up!
Mar 27, 2009 | Microsoft Windows XP Professional
What is the compatible database for visual basic 6.0?
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Mar 09, 2009 | Microsoft Press MS Access 2000 and Visual...
Write into excel format
Your code does not save in access format it just makes a copy of existing file. You need to open table by table and export data using csv format.
It can be done using access OLE to export, or
write some VB code to access the database tables via ODBC and save row data to csv file
Feb 17, 2009 | Microsoft Visual Basic Professional...
Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
welcome to fixya
plz tell us more about this error message
when does it come up and how offen and what OS your using
Jul 28, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
