Question about Kenmore 44072 Front Load Washer
Shutting down on rinse cycle
When washing in the normal cycle, any temp. setting, any spin setting, at 28 minutes, the washer will shut down during the first rinse cycle. When it enters the rinse cycle at 30 minutes, it spins a few times for a couple of minutes. At 28 minutes, when it begins to fill with water, it shuts down.
The same thing happens in the Quick cycle, at 17 minutes, same thing during the rinse cycle, when the washer begins to fill up with water.
  • 4 more comments
  • Anonymous Aug 06, 2008
    when it comes to rinsing on any cycle the machine just sits idle.
  • Bah Dee Jun 22, 2012
    Shesh,you have a different machine than I,but the situation seems to be very similar,however mine will finish the job putting it on the delicate cycle.
  • Anonymous Mar 13, 2014
    When machine goes into rinse cycle it shuts down
  • Anonymous Mar 20, 2014
    Only happens on start up of wash cycle, when water starts filling. Will operate the spin/rinse cycle with no problem.
  • Anonymous Mar 24, 2014
    Wanting to know if anyone else has had this problem before?
  • Anonymous Mar 26, 2014
    goes part way thru a cycle then stops and goes back to srart o cycle put on spin only for 12 minutes goes down to 2 then stops goesback to12
  • 4 Answers
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Posted on Sep 02, 2008
My Vabis 2010 washer shuts down during the rinse cycle rinsing normal-soiled items with cold water
FE: Water inlet valve stuck open
Water valve is stuck open and needs to be replaced. The best way to check if the water valve is the problem is to remove the top cover, run the machine to get the water running. While the water is filling, remove the connector to the water valve that is filling. If the water continues to run without the connector, the valve needs to be replaced. If the water stops flowing when disconnected, you may have a control board problem and will need it to be replaced
Jun 23, 2016 | Washing Machines
Hotpoint wma48 shuts down anywhere during cycle
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
May 23, 2016 | Hotpoint Washing Machines
Maytag washer (LAT7400AAV)shuts off during rinse cycle
The machine control board is programmed to allow a maximum continous fill time of six minutes
or an accumulated fill time of 8 minutes for each full wash cycle.
If the required fill time exceeds the time limit, the washer will shut down.
This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
Check the incoming water lines for a minimum pressure of 20 psi.
If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
An alternative solution would be to change the plastic inlet screens to metal screened washers
and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
Dec 10, 2014 | Maytag Washing Machines
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 44072 Front Load Washer Logo
750 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
