Question about Kenmore 98702 Stacked Washer/Dryer
Dryer no longer heats up on my Kenmore 417.94812301 laundry stacked unit
My dryer no longer heats up, everything else is ok on the unit, it's only about 4 years old. I have been told it needs a thermostat and a heating element. The repair was quoted at 420.00! Can my husband fix it without too much trouble and what are the part numbers? Thanks!
  • Anonymous Mar 24, 2014
    do I have to take the panel off in the back
  • 100 Answers
On your dryer the common problems found is either you lost some of your electrical power (check your fuse box) or you need a new heater #131475300 about $100 for the part.
Posted on Jul 29, 2008
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Kenmore stacked laundry unit. when it was plugged in sparks flew and small parts of the heating element fell and the power cord is ow black. can we replace cord and be ok
Heating element must be replacedas well as the cord. Make sure the drum screws were not screwed into anything electrical.
May 18, 2013 | Kenmore Dryers
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Our Kenmore Laundry Center makes a small squealing noise, and proceeds to get worse the longer the dryer goes on, it gets to the point where I can not even stay in the laundry room. Please Help
Your dryer has either a bad belt pulley or a bad roller. You will need to pull the drum out and look inside the cabinet. There are two rollers that the drum rides on and the pulley is close to one of them. It take the slack out of the belt. I would go ahead and change both the rollers and pulley seeing your at them because these stack units are not that easy to work on.
2162268t.jpgHere is what the rollers look like
383724t.jpgThis is the idler pulley
Get your model number and go to this site. and then enter your model number. They will have every thing you will need. even a diagram to help. You can buy the parts over the net with a card.
Please rate solution if it is helpful
Aug 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
No heat in my stack-pak kenmore dryer. The element is ok and there are no broken cables/wires. 220 does come in to the unit and show up at the componets.
There is a thermal relay switch that is blown. Replace it.
Model number please and I will give you the part number.
May 23, 2009 | Kenmore Dryers
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
May 07, 2009 | Kenmore 64992 Electric Dryer
If it is stack from the factory (ie..came as one peice) you cant
Jul 24, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
441 people viewed this question
Sal De
 Brian Main
Brian Main
