Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Prints blue and black only
Just changed color ink and it prints blue and black only Yes, my Brother MFC-240C will not print yellow. I have replaced the cart twice and have done multiple cleanings. Nothing seems to help. Any sugestion is appreciated.
Connie
  • scm1059 Jul 28, 2008
    Not under Warranty anymore. They sugested taking it to a repair shop.
  • scm1059 Jul 30, 2008
    Thanks so much for your help. If I knew how to get to the head assembly to clean it I would give it a try, but I don't even know where to begin. Have any suggestions? Not afraid to try. There is yellow ink around the base where the carts set. That tells me the ink is spilling outside of the line. The repair shop didn't even attempt to answer the messages I left.
    Scholar:
  • 32 Answers
I have had this happen on mine as well. The nozzles are not clogged (which cleaning would fix) the lines going between them and the cartridges most likely has a clot in it. Call in Brother's tech support and have it replaced by warranty, I have so far replaced for the same problem twice.
Posted on Jul 28, 2008
  • Martin Snow
    Martin Snow Jul 30, 2008
    Without a warranty, I would kinda say good luck. Unfortunately, most private companies do not do repair on MFC units, let alone most printers. One thing I used to do when starting out fixing copiers was take apart machines that would normally be too costly to repair. If you were physically go open up the printer and remove the print head assembly, you would be able to inspect the feed lines to see if there is a clog (easily fixed by taking out and feeding with warm water for a minute) you can do the same method to the head itself after it is taken out. Just use scotch tape to cover any copper contacts or any other connectors, then run the nozzles under medium hot water for a minute as you see a bunch of ink pour out of the insides, let it dry and pop it back in. It is a shot in the dark, but it will probably be a very small cost difference between depot repair and a new printer
My brothers mfc 240c printer wont print because one ink is not full but it has black
You need to have ink in all cartridges to print. You can put a small electrical tape over the little window on the cartridge to print with empty inks, but you risk an air bubble in the ink tubes. If you don't care about printing color at some time, just cover the window on empty carts.
Apr 20, 2010 | Brother Multi-Function Center MFC-240C...
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
Black ink does not print on brother 240c
If you haven't changed it recently, it may be out of black ink. The product code for Black is LC51BK.
Brother's supply site
Dec 10, 2009 | Brother Multi-Function Center MFC-240C...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Can't print documents from Word.
Did you do a test print by pressing ink testprint etc.? Do you have all colors incl. BK? If yes, check the printersetting WITHIN Word. Is the mfc the printer to be recognized by Word or is it another one? If you miss the bk upon the test sheet try to clean the ink cart by help of pressing ink arrow-down-button (cleaning) and (blue) start mono. If there is no or not enough ink check the cart. In case you use third party ones, use an original brother cart and do the cleaning twice. Third party carts do make a lot of trouble due to malconstruction!
Oct 10, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
208 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
