Question about RCA R52WM24 52" HDTV Projection Television
We have a RCA 42 in wide screen and it is sparking....
And making hissing sounds In the back we took the back cover off of it and we found what part is was but can not find the part online we have a few #'s but can't find any of them. It looks like an easy fix that we could do.
  • Crystalslife
    Crystalslife Jul 28, 2008
    sorry it is RCA 52 in # R52WM24
  • Crystalslife
    Yes that is the part that is sparking and hissing.
  • RCA Master
  • 8,617 Answers
Does the part look like the item that is circled? Let me know and I will post a link where you can get a new replacement with free on line tech support to give you step by step instructions on how to replace the copmponentWe have a RCA 42 in wide screen and it is sparking - 8f159f6.jpg
Posted on Jul 28, 2008
  • Sonny Berry
    Sonny Berry Jul 28, 2008
    Thats a very easy and inexspensive part to replace. You can get a new replavcement at the following link and they will give you free online instant messageing with a repair tech that will take you step by step through the entire replacement when your part arrives. Heres the link you need flyback number 259296. Its listed under their flyback catagory. Heres the link.
    http://servicemanuals.vstore.ca/
Engine makes hissing noise. Valve cover or just a gasket?
Soounds like it to me.... But to be sure, knowing the make, model & year of the car would be a huge help!
Jul 23, 2016 | Cars & Trucks
Capacitors are fine but no picture for rca tv
It could be a y-sus or z-sustain. There should be fuses located on both boards. Check the fuses for continuity.
Sep 02, 2012 | RCA P42WHD33 42 in. Plasma HDTV
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
My toshiba tv wont turn on
FIRST GREEN LIGHT WOULD COME ON. TOOK IT AWHILE BUT ITWOULD FINALLY TURN ON...NO NOTHING. IT'S GETTING SPARK CAUSE WHEN I PLUG AND UNPLUG IT AT THE SOURCE OF ENERGY IT SPARKS. FUSE IS NOT BLOWN
Feb 13, 2012 | RCA F27450 27" TV
How far in do the plates go and are they supposed to make a noise?
They should go as far so the back edge of the plates touch the back stop and the the metal clip on each side of the plate is touching the metal screen on the plate.
As far as noise, depending on the purification setting, they can make a hissing sound. If you see arcing or sparking, or hear any other noise other than a hissing sound, then it is time to replace the plates.
Hope this helps.
Jul 18, 2010 | Alpine Air XL-15 Air Purifier
No image and sound on the rca hdtv 50' power button flashing
sounds like a fly back problem
have a qulifyed tech check this out its high voltage leaking you are hearing.
esp if its a sqweek hiss sound.
Jan 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
42' rca problems
my tv did the same thing my power supply board had went out had to replace it now I have no problem did you notice a hiss when you cut it on if so it is the same problem
Apr 07, 2008 | RCA HD52W59 HDTV Projection Television
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
RCA R52WM24 52" HDTV Projection Television Logo
20 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
