Question about Sony VAIO Digital Studio PCV-RZ22G PC Desktop
Ethernet port lightning hit my phones and knocked out ethernet port I bought a new card but when i opened case I see that port is a small silver case on motherboard with foxconn on top and 3Q 3F-L9 on back is this replaceable and how does it remove from board Thanks
  • guyton Jul 29, 2008
    Very helpful worked great as soon as I installed Thanks
  • 99 Answers
Hi, I'm kind of confused by your request. Does the computer turn on? If it does, then the Ethernet port should be working on your computer. The only option to remove the Ethernet port from your computer is through soldering, and that generally isn't recommended.
Hope this helps
Posted on Jul 28, 2008
  • Madhav Suresh Jul 28, 2008
    You say you bought a new card, did you buy a new ethernet card?
  • Sony Master
  • 6,487 Answers
You can just look for available PCI slot on *********** board the colored whit that's where you can plug that new ethernet card that you just purchase and no need to remove the old one.
Hope that helps..............
  • Mark Gil
    Mark Gil Jul 28, 2008
    You can just look for available PCI slot on motherboard the colored whit that's where you can plug that new ethernet card that you just purchase and no need to remove the old one.
  • Mark Gil
    You can follow the instructins for that new ethernet card and the old ethernet card just leave it there I believe that's the built in that came with the motherboard..
    Good luck...........
Lightning nocked out ethernet need netcard
The simplest way, without opening the computer, would be to get a USB ethernet card, such as this:
Amazon com Cable Matters SuperSpeed USB 3 0 to RJ45 Gigabit Ethernet...
Secondarily, you would have to consult your owners manual on what type of expansion port(s) you have internally, then purchase an ethernet card, similar to the one in the link below, and install it:
Intel PWLA8391GT PRO 1000 GT PCI Network Adapter
Sep 02, 2014 | Gateway Factory Refurbished SX2110G-UW23...
Samsung tv lightning
If lightning knocked it out warranty should cover it.
Oct 04, 2013 | Samsung Televison & Video
Ethernet port not functioning after lifghtening strike
Ethernet port not working after a lightning strike? Then I suggest obtaining an inexpensive Ethernet adapter card, and installing it.
One example of an Ethernet adapter card, (Ethernet Card, Networking Card - Same/same),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1275962&CatId=200
The above Ethernet adapter card is a PCI style of adapter card. It plugs into any available PCI expansion slot on the Pavilion a620n's motherboard.
This is an illustration and photo of the Pavilion a620n motherboard from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=424215
Scrolling to the middle of the page shows first the illustration, then the photo.
In the motherboard photo the three white long expansion slots on the bottom of the motherboard, are the PCI slots.
On this page is information on how to open the computer case, and replace, or install an Ethernet Card,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=424215&
Click on ~ HP Pavilion PCs - Upgrading and Servicing Guide
This is a PDF file. You may have to allow up to 30 seconds to see the first page, and additional time for the file to fully download.
[Removing and Installing an Add-In Card is information on how to remove, and install an Ethernet Card. An Ethernet adapter card is an Add-In Card]
For additional questions, and/or clarification on what has been stated please post in a Comment.
Regards,
joecoolvette
Apr 30, 2011 | HP Pavilion a620n (PC028A) PC Desktop
What ethernet card to install Dell Optiplex GX 240? one attached to mo works intermittently - loose.
You can use any brand of Ethernet card in this computer as long as it will fit in the case. If your GX240 is packaged in the small form factor case, you'll need a low-profile card. (Low-profile cards have a shorter mounting bracket than regular-size cards which won't fit this case.) For the small desktop and mini-tower cases you can use any card.
If you want to avoid having to open the case and fit a new card, consider a USB Ethernet adapter. All you need to do is plug it in to an available USB port and you're done. No opening the case and worrying about installing a card. These adapters are available at some retailers and through online vendors.
Whichever way you go, just be sure to go into the computer's BIOS settings and disable the integrated network connection.
Hope this helps. Thanks for using Fixya!
Feb 15, 2010 | Dell OptiPlex GX240 PC Desktop
Modem bad on Dell Dimension 2400, Can it be replaced?
Ethernet port or dial up modem?
If it's the built in ethernet port, all you need to do is purchase a PCI ethernet card, disable the one that's built in in the device manager and you're good to go.
Thanks and please take a moment to give this solution a rating of fixya.
Mar 11, 2009 | Dell Dimension 2400 PC Desktop
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Replacing an ethernet port on my hp pavillion
Your ethernet port is probably integrated into the motherboard of your computer. Have you tried reinstalling the driver for the ethernet?
If the port is truly bad, my suggestion would be to purchase an ethernet card or NIC (Network Interface Card) and have it installed. You can get them for $15 to $25 at any big box computer store.
Nov 04, 2008 | Computers & Internet
Can I get the internet on compaq armada 1700 laptop?
That phone line will only be for actual phone lines.. as it will be a modem.
If the lappy has an ethernet port (slightly larger than a phone port, but looks the same) you could use that with an ethernet cable to a DSL modem. (the modem has the phone wire plugged into it)
Most laptops have an ethernet port, but yours might be a bit too old perhaps? If that's the case, you can buy either a USB to ethernet adapter (but you might not have that either) or a PCMCIA ethernet card. The latter will definitely work for you, and can be bought second hand VERY cheaply... if not for nothing.
I really hope it has something a bit newer than '95 though... otherwise just getting the internet to work could be a problem. Good luck!
Jul 14, 2008 | Compaq Power over Ethernet 12 Port...
Rg54g3 router problem
Lightning seems to have zapped the Ethernet port on the Modem side, the WAN port, this is quite common with telephone and cable line surges.
Consider your router smoked.
Apr 07, 2008 | MSI Wireless-G RG54G3 Router
Tv wont come on
Hi, unplug your system from the wall then open the case and use a torch to see inside of the machine. locate your video card and examine the capacitors, these are the round things with silver tops on them. If any of them have a raised or bulged top or have leaked out the bottom then the lightning has over heated them. the only solution is to then replace the card. Goodluck. msityman
May 16, 2007 | Philips TV Tuner Video Capture PCI Card -...
Sony VAIO Digital Studio PCV-RZ22G PC Desktop Logo
146 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
