Question about Dometic Rooftop RV Air Conditioner
Duo-therm a/c we just turned on travel trailer a/c it makes a loud rumbling sound whole unit shakes roof. It was working fine 2 months ago when we used it. Any answers
  • Anonymous Mar 24, 2014
    Just bought trailer. Tried ac unit at old owners house and worked fine . Get home turn on ac and all it does is makes a sounds like a motor has locked up. Trailer is on 2 ext. cords both #10s . Circuit at house is 15 amp. Older model of trailer. Do i need a 30 or 40 amp service to make this ac unit work?
We had this issue also and dirt daubers had built a nest on the end of the fan blade
Posted on Aug 11, 2008
  • Dometic Master
  • 6,674 Answers
Yes I'd be leaning toward mud wasp nests too.
Posted on Aug 14, 2008
    Scholar:
  • 121 Answers
Fan blade or bearing on motor are bad.
Posted on Aug 07, 2008
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
My Duo Therm furnace was working last night and not this morning
I would make sure there is power to the unit before I attempted any repairs. Gas being available will not allow the thermostat or gas valve to operate if there's no power to them
Dec 04, 2013 | Heating & Cooling
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
Duo therm 57915.331 not cooling
make sure fan on auto and on cool if ok bad cooling unit
Jul 05, 2012 | Dometic Rooftop RV Air Conditioner
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
Ac unit blowing water with air on after a few minutes
2 things to check, one is remove filters on inside & look at front coils to make sure they aren't frosting/freezing up. The other, remove cover on upper unit & check that drain holes in base are not plugged. Be careful of wasp nests when removing cover. If neither one of those is problem, you may have a cracked drain pan, which you can also observe/inspect when cover off on roof unit.
Jul 21, 2009 | Heating & Cooling
Fan will not come on
maybe the capacitor for fan was already busted try to check that.
May 17, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
418 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
