Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana DRSE663BW Just wanted to know if you guys new exactly where the defrost timer board is. Im thinking its behind the controls for the refrig & freezer inside the refrigerator. Another ? i have is do you know what it takes to get in there. I removed the obvious screws one on the outside and one on the inside through a slot. Still doesnt wont to come off. Any suggestions will be greatly appreciated
  • brianp66 Jul 28, 2008
    thanks it was in the refrigerator i just needed to pull out the knobs then it came free.
  • 77 Answers
Usually behind grille in front of unit. some of the newer units do have a small board in the refrigerator. there are plastic clips on the back of housing near the light bulb that can be easily pried out. if it is too hard to remove then that is not likely to be where it is.
Jim
Posted on Jul 28, 2008
I replaced the Defrost timer and I still have to smack the area where the timer is to get the compressor to kick on and then it doesnt stay cold after the initial freeze. The freezer will defrost the
check out the control board behind it
i dont know the exact freezer
but probs ive found before are bad solders on the control board
where relays are
and around other connections
its behind the timer at the top????
usual place
so get out the solder iron
could also be a bad relay
its contacts platings are gone and become resistive
other than this it could be the evaporator tubes are blocked up
or the fan needs attantion {behind the freezer rear panel
lift it out check the fan clear any ice
clear and salt the water guides and drain hole./ tubes
hope this helps
have a happy crimbo
Dec 09, 2014 | Whirlpool Refrigerators
Tt18hpxlt defrost timer
there is no defrost timer in this model,it is called an A.D.C. adaptive defrost control and is located in the refrige compartment just above and behind the cold control setting inside this plastic case,remove this case from the top of the refrigerator compartment and you will see a small printed circuit board,this is the A.D.C.
May 12, 2012 | Estate Refrigerators
GE model #GSS201EMBWW is not defrosting, checked defrost heater and it was burned out. Replaced with new 2 heater design and now it burns all the time, which is most likely what burnt the other 1 out....
This is how the defrost works . I have NEVER found a defrost problem associated with a bad main control board since these computerized GE's came out in 2000 . Lots of thermistor problems , lying to the board , causing different problems .
Your GSS model refrig does not have a defrost timer . It works off of the main control board . Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Aug 30, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Where is the defrost timer locate
The timer is the main control board behind the refrig , behind the 8X10 panel . If you have a defrost problem , Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
I have never found a control board causing a defrost problem .
Aug 04, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Refrig. not cooling properly
if the timer is working the most likely problem is the bi-metal(also called defrost thermostat)it is the disc shaped piece that clamps to the coils behind the back panel.you could also have a problem with the heating element,these items require a multi meter to check
Jan 25, 2010 | Amana ABB1927DE Bottom Freezer...
Amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
I had a problem with refrigerator side not cold. I followed your suggestion and defrosted the freezer. The refrigerator worked for a week, now it is not getting cold. Is there some part that needs repair?
You have a problem with the defrost cycle. Your evaporator in the freezer is getting icedup and blocking airflow. I don't know your exact model but if it has a defrost timer then replace that and the defrost bimetal thermostat in the freezer. They are both cheap and easy to install. If your refrig has a control board then you will need to buy a new board because the defrost is controlled by the board. The boards are not cheap though.
Sep 08, 2009 | Kenmore Refrigerators
I have a model # HTS22GBMBRCC Hoypoint Refrigerator. the fan in the back runs all the time and I the fan inside the freezer is running all the time. Neather the Freezer or the frig is getting cold. I have...
Your model has no defrost timer . It works off a main control board . If there is frost on the rear panel inside the freezer , then you have a defrost problem . This would be another paragraph ( but let us know if there is frost and someone will be glad to help ) . If not any frost , then the compressor may not be running . If the compressor not running , main control board is bad Pt # WR55X10942 . You will have to pull out refrig and remove the panel covering at the bottom to check . The main control board , is behind the 8 " X 10 " panel at the top left , behind the refrig .
Sep 05, 2009 | Refrigerators
GE side by side refrigerator TFX22ZRA control board
The adaptive defrost on your model is controled by the motherboard, but I don't think that is your problem. If the freezer is too cold and the fresh foods is too warm, check the air dampener. It is a small duct door in the very back top left of the fresh foods section.
Jul 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana Fridge that won't keep cooling.
Inside your refrigerator fresh food compartment and behind the control panel is a Adaptive Defrost Board this could be the problem or the start relay and start capacitor located on the compressor. I would unplug and examine the defrost board first to see if it looks abnormal. Second I would replace the parts mentioned at the compressor if the Adaptive Defrost Board looks ok. Below is a link that you enter your model number in the model parts search feature. The part number for the Adaptive Defrost is 611005988
Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 28, 2009 | Amana DRSE663B Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
149 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
