Depending on the model number...sony had a bad run of amps that would exhibit the problem you are having...the fix was that it had a grounding issue with the various circuits within...there is a method we used to repair these sets where we would "bond" all of the grounding connections on the pc board with lengths of wire to one main grounding point...another possibility is that there are cold solder connections that are causing the unit to shut down. A cold solder connection may have conductivity when the unit is off, but when the unit heats up then the connection is lost resulting in shut down....I would recommend taking the set to your nearest service shop and get an estimate
I think relay protect
