Question about Whirlpool Duet GHW9150P Front Load Washer
Will not drain
Our machine will not drain and were getting the F2. We have taken all the clothes and tried to drain and spin but no luck. Please hlep
  • proemeling Jul 31, 2008
    my duet front load washer will not drain. timer blinks time on various settings but will not turn off with cancel button and does not respond to lock button either. Just keeps blinking time.
  • 770 Answers
Remove the bottom panel 3 screws and there is a lint filter clean out twist it and check for blockage
Posted on Jul 30, 2008
Washer not draining but motor still hums
I would get to the water outlet pipe and blow hard down it to try and clear any blockage if not take the pump housing apart to clear the blockage eric
Dec 24, 2017 | Kenmore HE2 Plus Front Load Washer
My Duet front loader.. once it starts washing it stops and an error f2 code comes up and it will not complete the washer the clothes are left wet. if i move to spin only it still wont same code comes up
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore Elite QuietPak 2 front loading washer..lately it has been taking FOREVER to finish a cycle (always stalling at 0:01 when cycle is about to end) Suggestions??? I am also using HE detergent...
Where you able to check the operation of the drain motor when yo removed the filter for cleaning?
If not please see the extract of my guidance notes ;-0)
REMOVE POWER
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Mar 25, 2011 | Kenmore Elite 45986 Front Load Washer
F2 Shows up on control screen and cloths dont go throw spin cycle.
F2 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Whirlpool GHW9400 Front Load Washer
Washer won't drain or spin, get F2 error
Hello hernandez160,
The "F2" error is referring to excessive drain time. Unplug machine before working on it. Remove screws on bottom of lower panel and remove panel. The drain pump is behind the panel, It has a large round door on it, turn counter clock wise by hand to access pump clean out. Have lots of towels ready. Remove anything from pump (usually kids socks or small clothing articles). If nothing in pump clean out remove suction boot from drain pump and check there. If nothing there blow through the drain hose from the pump side to check if anything is stuck in the hose. If that's clear check the electrical connection on the pump, make sure nothing is loose or broken at the connection. If all this checks out good and it still wont work you probably have a bad pump and it will need to be replaced. If you do find something was blocked or clogged due to small clothing articles I would recommend a garment/lingerie bag to keep all the small stuff together during the wash cycle. Hope this helps to fix your problem. Please remember to rate this and every solution you get.
Thanks,
edgin96
May 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpoolfront load duet washing machine
"F02" is a Long Drain error. This could be caused by a number of things. The likely suspect is your drain pump. Please click on the following link for instructions on how to diagnose and repair this problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
I hope this information helps you. Please post back if you need further advice. Go to my profile and use the "Ask Me" feature for a quicker reply.
Jun 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lg Front loading washing machine
most times on the Lg washer the lint trap is clogged and something may be hitting the impeller on the pump and causing it not to drain. remove the plastic cover on the lower left bottom and unscrew the black lint filter at the pump. you will get water on the floor there is no way to avoid that. clean the trap and make sure there is nothing inside the housing to block the pump impeller. replace the trap and run a rince cycle to check for proper draining.
Aug 04, 2007 | LG WD-1080FD Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal De
