Question about Microwave Ovens
Whirlpool Over the Range Microwave won't heat
This is the second time the heat stopped working on our microwave. It was built in 2004 and have had it fixed once before, but is no longer under warranty. Could I fix this myself? The model # TRR4273020.
  • 4 more comments
  • ked0603 Jul 29, 2008
    The model number is MH11500XMB-1
  • ked0603 Aug 04, 2008
    The turntable and light do work when I try to cook.....One important thing I forgot to mention is it stopped heating when I adjusted the power level on the microwave.
    I don't know what was replaced before when it was fixed, but it was only 3 months old when it went out.
    Katie
  • ked0603 Aug 06, 2008
    Can anyone help me?
  • onegr8scorpi Sep 02, 2008
    replaced light underneath microwave without unplugging the unit. the light bulb exploded in my hand. replace bulb, now unit will not heat, the display still works. removed circuit board from behind display and found a burnt trace to a black relay. solder on wire were burned trace was and still having the same problem. it might be the circuit board, but i'm not sure, any suggestions.
    bryan
  • William Miller
    William Miller May 11, 2010
    Okay, that's better. MH1150XMB-1 I would say.
    Are the turntable and inside light coming on when you try to cook?
    What was replaced before to fix it?
    Feel free to contact me directly.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
  • William Miller
    That model number isn't showing up. Is it a US model?
    Can you double check that?
  • Microwave Ovens Master
  • 9,098 Answers
Yes, I'm trying to help you. Sorry about all the questions, but it's part of diagnosis.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose or corroded connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron
- shorted high voltage diode
At this point, it seems pretty clear that the problem is in the high voltage section, most likely the magnetron, but possibly the high voltage diode or transformer..
Here are some links you or someone you know can use for test help to find the defective component, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Aug 06, 2008
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Samsung over the range microwave oven model# SMK9175ST the microwave part stopped heating
If "everything" works and your microwave just stopped heating, the problem might be with the internal door switches, the high voltage circuitry, or the circuit board or quite probalby your magnetron is dead. If you don't have the technical knowledge to repair microwaves, you should take it to a repair service for diagnostics.
Jul 16, 2015 | Samsung 1.8 Cu. Ft. Over-the-Range...
MY MICROWAVE IS NOT HEATING
If the microwave is turned on and you can hear the fan working when you set the time you should make sure of those things:1. You have selected the proper programme. Some microwaves have a control desiged to use the programs on the buttons. if you want to you the buttons to set time you should select "microwave" or a similar button and then press the power level like "1", "2" or "80", "100" (being percentage) and then press the buttons for timing.2. If you have used it for a while and it suddenly stopped heating the food, than it could be that your magnetron (a spare part) has burned out. Have a specialist replace it, or just get a new microwave, the price difference won't be that great for standard issue microwaves.
Feb 25, 2012 | Whirlpool Microwave Ovens
Our Whirlpool over the range microwave makes a clicking sound for a few seconds then shuts the microwave off. The microwave is unusable. The sound seems to be coming from the control panel.
If the cooling fan is not working, that would explain the shutdown problem. The function of the fan is to cool the magnetron down when it is warming or cooking the food, if the fan fails to run, the thermal fuse will detect heat rise causing a shutdown with in 5 seconds or more, the clicking suggest fan issues. I would recommend a whirlpool technician to go through the system.
Jan 27, 2011 | Whirlpool MH7140XF Microwave Oven
Built-in microwave stopped heating repair or replace
Hi, Replace...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 11, 2009 | Whirlpool GH4155XP Microwave Oven
My Whirlpool over the range microwave works but
heatman101
xz
May 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Microwave doesn't work
The magnetron is dead. it can be replaced if you do it it is cheap if you call a repair guy its cheaper to get a new one.. parts roughly areound $100
Nov 26, 2008 | Whirlpool Microwave Ovens
Microwave heating problems
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
Oct 03, 2008 | Whirlpool Microwave Ovens
Whirlpool microwave mh6150xls makes noise while running
The oven may not be seated properly. check the bushes at the bottom.
Apr 07, 2008 | Whirlpool MH6150XMS Microwave Oven
Whirlpool microwave, intermittent blower activity, shuts down microwave
Not clear what to explain but would look at the front control switches, commond problem, to see just play with the door open and closing to see what happen's with the fan, it's probroly not making proper contact, the other problem I can thing of is bad thermal heat sensor, there should be two or three of them, you need to know the basic what they do to test them just jump them, and try the unit and see if the problem stop to see witch termal is deffective.
Hope this help
Bob The builder
Feb 07, 2008 | Microwave Ovens
Microwave Ovens Logo
3,549 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
