Are there any step by step direction or for viewing i am trying to use tune tools. I am not computer savy and worried about screwing up.
  • 99 Answers
Check out this website:
http://www.valusoftsupport.com/Results.asp?search=full&show=titles&results=20&submit=prod&pid=422
Posted on Jul 28, 2008
Can i play the image which is Jpg format directly on projector saved in USB?
I started an answer to this post earlier, but my browser closed
Here we go-
Simple answer is yes, if your projector has a USB slot. If so, the ability to view it will be a choice in the projector's set up menu
If it does not have a USB slot, then it is still possible to view it using your computer
Step 1: turn off computer & projector, then get this type of cable (seen below)
Step 2: connect cable to the VGA ports on your projector & computer. On the computer, this is where your monitor us currently connected. It will only fit on the ports intended for this purpose, so don't worry about goofing it up
Step 3: turn both computer & projector on. Newer computers will recognize the connection automatically. For laptops, there will be a button to push (on the top row of keys usually). It looks like a monitor most times.
You may need to go into the projector's set up menu to specify which connection. It should say VGA. Select that and you will be able to project your computer/laptop screen.
Insert the USB media (thumb drive?) into the slot on the computer and on newer computers, a notice will appear asking you what you want to do with the newly inserted device. Select "view file/contents on drive", then choose the JPG file(s) you wish to view
Good luck & Let me know if you need further assistance
Nov 18, 2016 | Cameras
How do you replace a hard drive in white imac 2006?
First Gen Intel iMac Hard Drive Replacement Part 1
I would take a look at this video to see if this is something you want to take on. These are not the easiest computers to disassemble but if your good at following directions and if you have the right tools, you should be able to do this.
May 13, 2014 | Apple iMac Computers & Internet
Windows password
Hello, you can reset Dell laptop login password by Smartkey Windows Password Recovery, just do as the following steps,
Step 1: Download the above Windows Password Reset Tool setup file and install it.
Step 2: Launch Windows Password Recovery Enterprise and create a windows password reset bootable USB pen drive to make the application Bootable. All this steps should be done on any computer you have access to.
Step 3: Now go to the locked computer and insert the Bootable Windows password reset pen drive you just created.
Step 4: Reboot the locked computer and follow the instructions to reset forgotten windows password.
Whiel you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Jun 01, 2012 | Dell Inspiron iM50302792B3D Notebook
Sony vaio desktop all in one back light not working
To fix your problem please follow the below given steps
Step1
Power on your computer and wait until there should be an image displaying on your LCD monitor. Look directly into the monitor from a distance of about 1 inch way. Cup your hands around your face to block out the light in the room and get a clearer view of the LCD screen. Check to see if there is a faint light visible in the screen, which will indicate that the cold cathode backlight has gone out, or no image at all, which will indicate a different problem.
Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb
Step3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
Step4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the back light directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
Step5
Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
Step6
Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
Step7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the back light bulb was installed correctly.
Please rate me if this solution works for you
Thanks......Have a great time.
  • Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb.
  • Step 3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
  • Step 4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the backlight directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
  • Step 5 Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
  • Step 6 Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
  • Step 7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the backlight bulb was installed correctly.
  • Read more: How to Diagnose & Repair Desktop LCD Backlight Problems | eHow.com http://www.ehow.com/how_5038642_diagnose-desktop-lcd-backlight-problems.html#ixzz0uJr4tmU8
    Jul 20, 2010 | Sony VAIO PCV-V200G PC Desktop
    Same problem as the first guy
    If you are not computer savy, it is dangerous to play around with the registry. If you screw up the registry the computer won't work and you most likely need to reinstall Windows.
    What do you want to do in the registry?
    If you need to fix and or cleanup the registry for some reason there are Registry fix programs on the Internet, it is a safer option than trying to fix the registry yourself.
    Do a Google search for these programs on the Internet.
    Jul 01, 2009 | Toshiba Satellite A135-S2386 Notebook
    When I put my earbuds into my ipod touch only one side works
    For the iPod nano you can replace the headphone jack your self for under thirty dollars. Even cheaper if you get the basic tool kit for it. :)
    Step 1 Gather the needed tools. Copy an paste the URL below in your Browser window to view the needed items and purchase them if you wish. :)
    http://www.rapidrepair.com/shop/1073-deluxe-tool-kit.html
    Step 2 You need to remove the bottom bezel 1st. Take a flat head or safe open case tool and slide it in the crack of the bottom. Be careful not to pry to hard or you will break the bezel where the dock port hole is. This bottom piece is held on with mild adhesive.
    Step 3 Once the bottom panel is removed, take your + driver and remove the 2 visible screws.
    Step 4 There is one other screw that is hidden under the headphone jack. You will not be able to remove the bottom metal dock bezel until this hidden screw is removed. Take the flathead and pull the headphone jack out very slowly & carefully.
    Once you have slid the new headphone jack into place just go backwards to reassemble.
    The actual part is only one dollar! :) Here is the URL to view the part and decide if you wish to go that route instead of apples so called great rout of Charging a lot of money for something so small and simple.
    http://www.rapidrepair.com/shop/1126-headphone-jack-module.html
    ON the web page www.rapidrepair.com you can also get the free guide to repairing your iPod touchl. Please let me know if any of this information is unsatisfactory or if you have any difficulties. And also remember to rate our experts ;)
    May 21, 2009 | Apple iPod nano
    How to turn zhone 6218-i2 router to wireless, now am using cable?
    hi Jeffkrick.
    if you go to the link you can read the manual.
    when you open this link you will see the pages at the top of the page just click on the pages and it will let you read it.
    Zhone 6218 I2 User Manual
    Nov 21, 2017 | Zhone (6218-I2-200) Router
    Veideo conference with webcam
    on yahoo clik to talk to him in conrer dsays start video chat or have him start web cam then nextto his name on yhaoo msg buddie list says view my web cam clik on that hell acept it so u can see him
    Oct 06, 2008 | Yahoo Messenger
    29 people viewed this question
     Grubhead
    Grubhead
