Question about Hampton Bay 52 In. 5-Blade Fan, Iron Oxide, Double French Scavo
Reverse how do you make the blades reverse? i would think it would be on the remote control .....
  • 75 Answers
You can make the blades to run in reverse direction by just interchanging the terminals where the supply is connected
Posted on Aug 01, 2008
How do i change the direction of the rotation of the blades on a model 52-DA? I understand it's done through the remote control but I don't have the instructions for the remote.
There may be a switch on the side of the wiring housing to effect reverse rotation. If the remote does not have a fan reversal button, it can't reverse rotation.
Jul 05, 2016 | Hampton Bay Dryers
I have a sidewinder model 312 342 in which we only use the hand remote. The wal mount remote was not installed. The hand remote does not have the feature to reverse the blades. is there another remote...
The short answer is no.
Since it is not a function of the fan's original remote control buying any remote that has this (as a custom feature) will never work with your fan. . . Sorry
Explanation:
Since you usually only change the rotation twice a year this is accomplished by a switch on the fan itself.
During winter heating, to help move warm air that is trapped on the ceiling, blades should turn 'forward' in a clockwise motion. This movement will push up the air and pull the warm trapped air down the sides of the room improving heat distribution.
During hot summer weather, to help produce a comfortable breeze or 'windchill' that cools the skin, blades should rotate in a 'reverse' counter-clockwise motion. The air movement has the same comfortable effect as when you fan yourself with a magazine to get relief from hot, stifling air.
Hope this helps,
The Tinkerer
Nov 30, 2013 | Hampton Bay Ceiling Fan. Sidewinder 54 in....
Reverse hunter mission fan
need to know how to programme carib 880e remote
Jul 23, 2013 | Hunter 54"" 1912 Mission 5 Blade Ceiling...
Ceiling fan remote
What make/model of fan do you have? If it was an add-on remote you probably have to use the reverse switch on the fan.
Jun 29, 2013 | Dryers
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
How to make the fan reverse
There 'should' be a small switch just below the fan blades on the center dome that will slide up or down. It is usually square and black. Slide it in the other direction....
Jun 24, 2009 | Universal Remote Control Hampton Bay...
How do I reverse the direction of the fan blades to counter-clockwise on the fan? The fan is a Hampton Bay ''Clarington'' with a remote control.
There is a small black switch on the switch housing directly under the blades. When the fan is completely off, move the switch to the opposite direction.
Mar 31, 2009 | Universal Remote Control Hampton Bay...
My fan reversed, but my controller does not have a reverse button
There is a switch on the housing of the fan. It is under the blades and above the lites if you have lights. Also same area as the chains. That is the reverse switch you might have hit it when cleaning the fan. just flip the switch iy goes left to right or reverse.
Good Luck and please rate
Jan 23, 2009 | Minka -Aire Brushed Nickel Remote Control...
HOW TO CHANGE DIRECTIONS OF BLADES ON HAMPTON BAY MODEL #70226
There is a switch on the side of the fan motor housing. Slide it the opposite way to reverse it. Make sure you wait until the fan comes to a complete stop to do so. Never reverse it while it is running, you could overload the motor and ruin it.
I believe they don't put the reversing switch on any remotes for that very reason.
Sep 15, 2008 | Universal Remote Control Hampton Bay...
Hampton Bay 52 In. 5-Blade Fan, Iron Oxide, Double French Scavo Logo
135 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
